1986.5 7mge -> 2jzge my very first build.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
You can call scheider racing cams
They will do custom re-grinds for around 200 a cam I believe, just send them a core.
That's who I went to for a 272 cam, they do great work
Sent from my PC36100 using Tapatalk 2
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
edited my first post, they are schneider cams, not crower.
im not sure of the exhaust housing size, its whatever stock is off a 1998 cummins 12 valve, divided.
1986.5supra_kid
Rice? No its Corn (E85)
im wondering if i need to leave my turbo alone and just do the cams and cop or if the compressor upgrade will benefit. i what does a larger compressor wheel do besides more flow? if i understand this correctly the cams will flow more and that same 16lbs will be enhanced. then the cop will help with a hotter spark and larger gap for staying lit underboost and a larger gap will make for a nicer idle with less miss(currently .22 gap)
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
cams will flow more air and so will the compressor wheel upgrade.
depending on which wheel you go with, you might push up your full spool up a bit. im not sure what your at now, but mines at 4000rpm with 62mm wheel, 272 cams, 3.5"downpipe and full 3"exhaust to 10" cherrybomb glasspack and hks hi-power muffler
you can go with a bigger compressor wheel/smaller exhaust housing and still spool quickly, but not have the top end power
1986.5supra_kid
There is a guy on SF with a GT3582R in .63A/R with a T3 flange, with a stock block 2JZ-GTE making 497whp and full boost by 3.2k. That was with everything stock, that turbo, and a MAP-ECU2 on pump gas. And the power held till 7k
So I'm thinking about a turbo modification.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Changing to a different turbo can be expensive
Why not turn up the boost and run water meth injection? Just my .02
supraguy@aol
Well-Known Member
Dec 30, 2005
4,241
Atlanta
I would say first finish the mods you planned for the ignition, and then see where you are.
I think your current setup can do better.
Grandavi
2,664
Calgary, Alberta, Canada
Water/meth injection cools the intake mixture allowing for aggressive tuning without detonation. Most I have discussed this with use it after they hit about 550 rwhp. It does work, but I can't say anything about pros and cons having never run the setup.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,241
Atlanta
I really haven't heard of any cons, just the time and $$ to install it, which is reasonable.
And Adam- How much have you spent on tuning? You've been down there twice for a couple of hours each time, right?
You shouldn't be charged more than $100 per hour, I'd hope.
1986.5supra_kid
Probably $850 in tuning now. And 550whp would be outside of my goal. 450 is the goal on pump gas but the tuner is staying a little rich and not so much timing since its a daily and that I have NA pistons. He's afraid that the ring lands may break. If I had TT pistons he would be more willing to do a TT tune instead. I'm no tuner so I'll let him do his thing. I really wish I had someone smart to pick their brain on tuning. I just want a good tune. Not aggressive or too safe.can this be done on a aem?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,241
Atlanta
AEM is as capable a system as you can get without going to the pro efi or a haltech system, so yes- you can tune to exactly what you want with it.
I'm hoping your new ignition system will cure all your troubles.
Did you get the new speedo cable in it yet?
Grandavi
2,664
My tune will cost over 2k on the hks fcon VPro this upcoming week.
I thought the only way to steep the torque over the HP was to go out and spen 10k on a 2jz stroker kit. (Or build a 7m)
Doat
2,599
Houston, TX
I don't really see the point in shooting for a top speed tune since how often are you going to be reaching top speed? I'd shoot for more acceleration and response but that is just me.
