Speed/Density Settings and Configuration for an N/A 7M-GE
I have been running S/D for a week now. Below are most of the settings I'm using. The tuning info is included for reference ONLY, it is highly unlikely that those settings will match your engine's needs! VERIFY ALL YOUR SETTINGS!!!
Before you go plugging in the your MAFT Pro and try changing the settings make sure you are running at LEAST version 4.84 on the MAFT Pro. At this moment only the version of 4.84 which is linked to in one of the first posts of this thread has the required modifications for our Fuel Cutout switch. It is HIGHLY recommended that you use only versions of the MAFT Pro software that is modified to work with our ECU... failure to do so will render the FC switch inoperable and in the event of an accident could prove VERY hazardous! I will post when the newest version (4.89) is available with that modification.
The 7M-GE versions of the MAFT Pro software are NOT for use with a 7M-GTE! At best it won't run.
Below is a list of the various settings available in the MAFT Pro. I highly recommend you take some time to familiarize yourself with all of the sections, their selections and their purpose. Some of the settings you will see listed here are only found in versions of the MAFT Pro's software that is newer than 4.84.
These settings are not for a turboed 7M-GE. These are what I'm running on my N/A.
Menus:
CFG Settings
System Setup
Boost Control
AFR Tracking
Air Temp
Aux Trig
Tune High Load
Tune Mid Load
Tune Low Load
Tune Response
SensorMonitor
Spark WOT
Spark Aux
PT Tracking
Verify that all the settings listed here are appropriate for your setup.
CFG Settings
1) Vehicle Select ----- "Mode: 0"
2) # of Cyl. ---------- "6"
3) Displacement ------ "2.96 Litres"
4) Airfl Mode --------- "0 - Speed Density (with temp compensation)"
5) MAP Source ------- "0 - GM 3 bar sensor".
6) Load Srce (Dens Srce) - "0 - Use MAP"
7) Baro Mode -------- "Read @ Key-on"
8) F-Out Mode ------- "0 - Fuel Pump Ctrl" ---Do NOT set this to #4 "Supra MK-III"
9) V-Out1 Mode ------ "17 - Toyota VAF"
10) V-Out2 Mode ----- "0 - Use setpoint"
11) AFR Source ------- "1 - Innovate LC1"
12) F-In Mode -------- "3.5" MAF LS1" I still have my MAF connected to the system for comparative purposes.
13) Aux1 Mode -------- "0 - Aux trig OFF" ---Do NOT set this to #28 "Toyota VAF"
14) FlowErr Mode ----- "1 - SD / MAF" Again, this is set this way because I'm using a MAF for reference in my tuning.
Please not that there are settings available for #8 and #13 which may seem the natural choice, they are not. Use the settings specified unless you're sure your specific install requires something else.
System Setup
1) Main Scale ------ "0.0"
2) V-Out1 Set ----- "2.500"
3) V-Out2 Set ----- "3.600"
4) Afterstart ------- "2.0"
5) Lo Load Pt ------ "35.1" See post #45 in this thread for suggestions on calculating your load levels.
6) Mid Load Pt ----- "54.6"
7) Hi Load Pt ------ "70.2"
8) F Out Max ------ "0"
9) Tm Base -------- "0.0"
10) Tm Correct ----- "1.27"
11) AF TrDelay ----- "0.0"
12) FE Smooth ----- "40"
13) Use VE Table # - "2 - Use VE Table #2"
14) SpkBase -------- "15.0"
Boost Control
TPS Spool ----- "4.900"
AFR Tracking
Min TPS ------- "2.500"
Min RPM ------- "2400"
Min Load ------- "65.0"
Lean Lim% ----- "12.0"
Rich Lim% ------ "20.0"
Gain ------------ "6.0"
AFR 2000R ------ "13.0"
AFR 3000R ------ "13.0"
AFR 4000R ------ "13.0"
AFR 5000R ------ "13.0"
AFR 6000R ------ "13.0"
AFR 7000R ------ "13.0"
AFR 8000R ------ "13.0"
Aux% ----------- "0.0"
Tune Response
***NOTE: Verify ALL your settings!
TPS Enrich ----- "0.50"
TPS Decay ----- "0.70"
TB Size -------- "6"
TPS MAP Max -- "65.0"
MAP Enrich ----- "0.10"
Bst Enrich ------ "0.00"
MAP TPS Min --- "0.580"
MAP RPM Min --- "928"
MAF Lim TPS --- "0.000"
MAF Limit ------ "0.0"
MAF /Krpm ----- "0.0"
Lim MinRPM ----- "0.0"
Lim Time ------- "0.0"
PT Tracking
***It is NOT recommended that you use this function until your tune is close to finished.
Idle TPS ----- "0.560"
Idle RPM ----- "928"
Idle A/F ------ "15.1"
Cruise TPS --- "2.500"
Cruise RPM --- "4000"
Cruise Load -- "65.0"
Cruise A/F --- "15.0"
Lean Load --- "52.0"
Lead Delay -- "2.5"
Lean A/F ---- "15.9"
Gain --------- "6.0"
Enabl. Dly ---- "0"
NOTES: I am not at sea level! My loads will be lower than yours. See post #45 in this thread for suggestions on calculating your load levels. You will want to adjust all "load" settings accordingly.
Do not just blindly copy these settings, these settings are specific to my altitude and engine.
You will note that my Lean Load is set lower than my Cruise Load. This is because if I am cruising and happen to be in a slightly hilly area my engine's load will shift beyond my Mid Load levels. While the level I have set should be safe for running at an AFR of 15, I'd rather not risk running an AFR leaner than that beyond my Mid Load level.
Menus:
CFG Settings
System Setup
Boost Control
AFR Tracking
Air Temp
Aux Trig
Tune High Load
Tune Mid Load
Tune Low Load
Tune Response
SensorMonitor
Spark WOT
Spark Aux
PT Tracking
CFG Settings
System Setup
Boost Control
AFR Tracking
Tune Response
PT Tracking
Lead Delay -- "2.5"
Enabl. Dly ---- "0"
