When you first get everything hooked up go into the SensorMonitor screen in the MAFT Pro's menus. Set any one of the four monitors for "MP". That's what your ambient manifold pressure reading. In Denver (way above sea level) I typically see around 84KPA, yours will be closer to 100KPA. You want to set your HIGH Tune Load to about 12% less than the ambient value. Somewhere between 10 and 15% is where I think we'll end up finding our desired target, still working on this one. 100 x .88 = 88
Then to figure out your MID Tune Load you'll want to take about 35% off of the ambient value. 100 x .65 = 65
For the low I've just gone with a default of 35. You can play around with this a little more if you find you need more or less scaling between your lows and mids.
Here's how these values are used:
Low Load Point = 35: Anytime the manifold pressure is at or below this value the Low User Tune fuel adjustments are used, they are not scaled in any way.
Mid Load Point = 65: When the MAP is AT 65KPA the Mid User Tune values will be used without scaling. If you're MAP is between 35KPA and 65KPA the fuel value for any given RPM will be scaled between the value set in the Low User Tune and the Mid User Tune. So if your Low is at 0 and your Mid is set to +4 and the MAP is right in the middle the fuel adjustment will be around +2. Make sense?
High Load Point = 88: When the MAP is below this value, but higher than the Mid Load Point the fuel adjustment will be scaled between the two. If your MAP is at or above this value the adjustment will be as set in the High User Tune fuel map.
Other adjustments you'll need to make are as follows:
Boost Enrichment = 0.0
MAP Enrichment could probably be scaled back a little
TPS MAP Max I've got set for just a bit above my Mid Load Point. I've got it at about 20% less than ambient.
For now I would turn off AFR tracking, or set all the values in there for 12.5. If you do want to enable it set the min load for something close to the halfway point between your mid and high load points.
A lot of this you're going to have to feel out... I don't have much real world data to go off of just yet.
If you run into an issue AJ, PM me and I'll give you my phone number. It's easier and quicker.
