oh man, I just started tearin apart everythin on my cylinder head yesterday. took me about 6 hrs. to take everything off (not even rushing.. just takin my time).
anywayz, I took my cylinder head to the machine shop and they said that its a little warped. well, my car wasnt even blowin white smoke and didnt overheat but it did have some minimal oil and coolant contamination. but then the motor had been previously recieved a "head gasket replacement" by the previous owner, then I leter found out the head bolts werent that even torqued down to the right specs.. they we're a little loose when I took em off. no wonder there was oil/coolant contamination.
so, now I'm just goin to have the whole complete head job from my machine shop, it'll cost me $500 for verything, including valve adjustment.
also, I'm using a Felpro composite HG. it looked pretty good, and way better that the Ishino's. and I was thinkin about puttin a brand new Head Bolts from Toyota (any opinion on this??? since its only $60 for a brand new set)
I'm not going to shoot for crazy HP on my MKIII, 350 hp is decent enough for now. since I'm planning to put a diff motor in it in a couple of yrs..
anywayz, good luck to ya theKnifeArtist, I guess we're both in the same dillema here. even though I have the luxury of time, space and tools to take off the whole motor, but then I decided to just remove the head and leave the motor on the car.
it doesnt make any sense to pull the motor out when the motor only have around 80K miles and it had a good 180-190 psi worth of compression on all cylinders. plus I didnt have a really bad HG problem. so there wasnt any bucket of water inside the oil pan.
