They are 17 X 8 +38. They would sit about 1/2" in and out more then stock rims. So if you think your stock MK3 rims look aiight then they will work for you. But personally the offset is a little too high for me. But some think I am nuts
BorHor;884018 said:They are 17 X 8 +38. They would sit about 1/2" in and out more then stock rims. So if you think your stock MK3 rims look aiight then they will work for you. But personally the offset is a little too high for me. But some think I am nuts![]()
BorHor;799529 said:I have been seeing alot of wheel fitment threads on here recentley. So I hope this will clean it up a bit. Ask what you want about a wheels fitment and I will try and answer or actually anyone can help. Just remember 18" is not enough info. We need Diamter, Width, and Offset. With out those 3 there will be no answer.
Alright here is a list of things that fit which will be updated everynow and then.
18x8.5+35 & 18x9.5+35 w/ 245/40/18 & 275/35/75 tires
18x9.5+12 & 18x10+18 w/ 235/40/18 tires
18x8+32 18x10+35 245/40 275/35
18x8.5 +25 235/40/18 & 18x9.5 +30 265/35/18
17x8 Front +25, 225/45/17 & 17x9 Rear +39, 255/40/17
18x8.5 + 38 235/40 & 18.9.5 + 36 275/35
18"x9" - 255/35 (+38) & 18"x10" - 265/35 (+35)
16x8 +22 225/50/16 & 16x9.5 +35 245/50/16
18x9.5 +12 (rear only) 225/40/18
17x9 +20 all around
18x9 +37 front 255/35 and 18x10 +44 rear 295/30
17x8 fronts with 225/50 and 17x9 rears with 235/45 tires +36ish all around
18x10 +19 F+R
18x9.5 +12 in front and 17x10 +25 in the rear about -1.5 camber all around
18x10 +13 w/ 245 40 18 rear (Kinda fit)
18x8.5 & 18x9.5 w/+35
18x8.5 +32 235/40 & 18x9.5 +35 265/35
17x9 all around +35 255/40-17s
17x8 +27 245/40-17 & 2 17x9 +28 275/40-17
17x9+15 225/45/17 17x10+25 245/40/17
rear 18x10 +35mm front??
front 255/35 18's and the rears are 295/30 18's rims sizes???
18X8 +30 with 235/40 in front & 18X9.5 +45 with 255/40 in rear\
18x8.5 front with 245/35 & 18x9.5 rear with 275/35
Last updated 1-14-08 09:58 AM
BorHor;884218 said:What? you need to see how stock sawblades fit? you kidding?
TurboFreak;884223 said:With spacers or what? all sawblades are +38 offset.
We need to know some stuff. Aka. your ride height, if you are willing to roll your fenders, etc.
