Wheel Fitment & Question Thread
pejay
15
madison,wi
does center bore matter? can i just pick any center bore or does it have to be the right size?..whats the c/b for the supra?
Sawbladz
1,727
Oshawa, ON, CA
To do it properly you should get a hubcentric ring for the wheels.
ValgeKotkas
2,224
Over the pond
Question about tire pressure, probably the best thread for it :): Anyone have experience with 235/40/18 and 265/35/18 ? About how much would be needed to get even wear?
falconpunch1978
17
naperville il
My attempt at "VIP" style, 19" Racing Hart J8's 9 1/2" 235 front 11" 265 rear, flared fenders to fit wedsport wheels with 275 hoosiers and then had to buy spacers to make the 19's look right.
cool chuck
I like rims!
Nov 15, 2007
179
Maryland
Looks mean!
pnoixballa
15
Central NJ
I plan on replacing my sawblades with my tax return. I was thinking about going with 18s but I was wondering what's the widest i can go without having to roll my fenders. I was also thinking about a stretching the tire a lil bit. You can say I was inspired by Borhor. Lol.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
It isn't going to work with out rolling. I would say safest is 18x9.5 +35 with a 275/35/18 tire for the rear. Fronts depend on if you want to go staggered or not.
jackal613
15
Los Angeles, CA
Do you think the 18x9.5 +35 offset with a 275/35/18 tire would fit up front without rolling or pulling? Looking to go as big as I can up front and match it in the rear. Lowered on H&R springs if that helps any...
Sawbladz
1,727
Oshawa, ON, CA
You will not be able to run that much tire on the front with that rim. It will fit perfectly on the rear, but you will need to stretch it to fit the front. Not sure since this is more Borhor's area, but I think you would have to run a 245 to not rub. Wait for him to confirm though.
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
it has been done i know of two ppl with the same exact setup, however there not on h&r springs, one is one stock and the other is on eibachs i believe, I doubt that ull be able to do it on h&r's since the drop is so low.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
It can probably clear with a fender roll. If anything it will be rubbing on the inside. I had a 9.5 +15 in front with a 245 RE01R so it was fat and I didn't rub on the fender with a roll and pull though.
