Wheel Fitment & Question Thread
Sawbladz
1,727
Oshawa, ON, CA
Unless you run spacers, there will be rubbing issues at full lock. This is not dependent on tire size, this is due to the wheel offset. Mine rubbed with 225's up front. On the N/A wheels, I would run 245/45 rear and 225/50 front.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Im runnin a 1/4" spacer up front with 225's and 245's no spacer out back!!!
N/A MKIV's
HIDPLANET
89 1JZGTE
Well thats just whats on the wheels in question although id prefer to go with 255 or 265 but if a 245 requires a roll, then those tires might be out of the question. Just wanted to make sure the +30 offset doesnt hit anything on the inside of the well. ie. shock or spring
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Nope it will clear the inside fine. Your problem now is the fender. You might be able to fit more meat depending on how your set up is. I had a 17x10 +25 fit a 255 tire and it had a tick wall closer to a 265 or 275.
bluspd
4
texas
hey yall im a new member but not new to the site, which is the cats ass btw...anyway im thinkin bout runnin 19x9.5 +35 sportmax front and rear...first, will this work and second what size tires would be moderately stretched on these wheels since ill b lowered on coilovers.thanks
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
9.5+ 35 will look wack with a a stretched tire.. there is a member ,s0ulstar, who has has 275 tires all around and it is flush. If you want to have a stretched tire look please go with a lower offset or else it will look like crap.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Could I fit 1996 Mustang cobra wheels out back, with 275/40/17s on them, they are 17x8s, 5.72" backspacing with a 30mm offset. Just want to know if I will need a roll.
I am currently on eibachs and kyb gr-2s
bluspd
4
texas
i know the offset is high but im plannin to correct w around 10mm spacers...and is it 275 30?
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,080
Anaheim/West Covina, CA
I agree with Boris. Stretched tires with my setup doesen't look right. I'm running 275/35 all round. The fronts are flush, but the rears could use a 5mm spacer to make the wheel flush with the fender. I'm lowered on Tokico/Eibach with only rubbing on the fronts during hard cornering. But I have since, rolled my fenders and now I don't have ANY rubbing issues
bluspd
4
texas
thanks, i cant wait to get to work on my supra, its just been sitting forever because i couldent visualize what i wanted it to look like. then i found this thread...this forum kicks so much azz!
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
Am I reading a 275 tire on a 8" rim, correctly?
255 is typically bulged, a 275 would look really crappy.
245 is just right on an 8" rim... 235 is a bit of stretch, 255 is a bit of bulge.
bluspd
4
texas
what do u think bout 225 40s with spacers to make em hella flush...just really likin these cheap 9.5 sportmax..
Mofo
20
Perth, Western Australia.
Wheels
G.MAX Aspire (2008 Series)
Fronts = 20 x 8.5 +35
Rears = 20 x 10 +35
5x114.3
Best suited to the Wide Body A70 Supra.
http://www.gmaxwheels.com/
Tyres
Dunlop SP Sports Maxx 245/30/20
Dunlop SP Sports Maxx 285/25/20
http://www.dunloptyres.com.au/
Fitment
These have only been on two widebody A70's so the WB A70 is all i can gaurentee they fit...
These are BIG and WIDE wheels and despite the fact you can just bolt them on and drive away, you would be silly not to do some minor work to the gaurds. Work aka roll the lip on the rear gaurds and remove the plastic liner on the front gaurds. You would only need to do this when running a low ride height with soft suspension. And or if you plan on retaining 100% drivability of the car.
HOWEVER, all of the pics below of the green car, are 100% stock standard gaurds WITH liners. Athough I did experience rubbing of the front gaurds upon heavy cornering.
If you have standard ride height with stiff suspension chances are you dont have to touch a thing.
super7mgtepower
58
Lawton, OK
Very nice, crazy how those 20's fit. Well i bought some new wheels also two of them, except they dont fit the supra since their attached to a 2005 kawasaki z750s.:biglaugh:That means more time to work on the supra.:evil2:
