i was wondering what kinda oil should be used in the 1jz? 10w30 non syntheic? I'm not sure but i think turbo cars aren't suppose to run syntheic oil? could anyone tell me why?
bobiseverywhere said:i decided to use Royal Purple 5W30 jdub and jetjock have allot to say on the subject
check out this link, Great information about choosing your oil
suprastanger507mgte said:I use Mobil 1 10/30 Full Synthetic. NO problems whatsoever.
tissimo said:on my 1j i used 15/50.. but i think maybe it was a little thick.. on my 2j i'll probably use 10/30
tissimo said:so mobil 1 is now group III? interesting... maybe i should start using rp or something..
jdub said:That seems to be the consensus...at least for their top tier EP oil. Exxon is not saying, but various oil analysis is pointing at Group III for Mobile 1.
Consider the German Castrol 0W30 (European Formula)...it's an excellent oil and not nearly as expensive as RP or Redline. A good filter is just as or more important...Wix or PureOne are the best. NAPA Gold is a Wix filter
jdub said:Aaron - no offense, but I would not use a 50W multi-grade in my motor even if it was a synthetic and if had an unlimited supply for free. It will run ok, but is not good for the motor long term.
