My Supra love has been going on for 11 years now. This site, SupraMania, remains an inspiration for me. My goal now is to finish in 2017. Wish me luck! That said, I had a heart attack last Tuesday and I'm resting quietly at home this week... and watching a lot of videos. There are four or five welding jobs that must be completed to finish: pin-holes under the hood and in the spare tire well, a bracket for the front nose-piece, a captive nut for the driver's seat rails, and brackets for the six-point harnesses,... 36" of welds, at most. That said, I haven't done any welding since 1963, or braising since 1969. Bought a 90-amp, Harbor Freight, wire-feed welder almost two years ago... and the 15-amp circuit in my garage was never enough to get a weld going
A couple of weeks ago I picked up a HF 8750/7000 watt generator with 120v and 240v. My existing 15-amp circuit (compressor takes 13.2) is shared with four other garages. The low-end HF generator has a "20-amp" outlet, restricted to 13-amps with a circuit breaker, so there was no doing this cheap. The generator I got has two 20-amp circuits and one 30-amp 240 circuit. My HF 90-amp wire-feed flux welder will have full power, which is hopefully enough for me to re-learn to lay a pretty bead. If needed, I can upgrade to a better welder, and I have my eyes on Argon.
My 99-dollar welder has the right tip, right spool, right feed roller, all of that. The unfortunate part is that it's AC output, so it spatters... a lot. There are a couple of little mods and suggestions for making it better, but, nothing would help more than it being DC output. It can be done, for me, the capacitors would be excessively expensive, making an otherwise, 30-dollar mod, not practical, vs. the next model welder up. Clearly, Harbor Freight can be cheap stuff... it is cheap stuff that I wouldn't otherwise have.
The journey is just as important as the destination. The tools, the setup, the procedures and safety precautions, all as important as the job.
Things like 12-gauge extensions to all corners of the garage, 10-gauge extension on the compressor, grounding on the generator (although, some say the generator case is ground), proper adapters and extensions everywhere, and fire-extinguishers in every corner. My garage is located in a commercial building and my lease stipulates that I can do just about anything: specifically, welding, painting, running the compressor and generator... without any serious complaints. Four other garages in the building contain 3 vintage sports cars, a metal fabrication shop, a car-wrapper and a bunch of scooters stacked for a retail store. Good company, and a bunch of friends to teach me shit
As for the Supra re-fitting, there is still something going on with the heater controls down just above the steering column. I have a feeling that it needs to be done already, but, I'm still not sure how to run the speedo cable properly. I have a decent dash with a minor exception, my mind keeps seeing the six new gauges and a huge touch-screen monitor. I will save or sell the original dash so it can always become an option if what I do turns out badly. If I spend 1000 bucks on gauges, that means another 1000 will have to be spent on either a stand-alone or a piggy-back management system. I see no reason not to highlight that 2000 and the fact that I actually got it all working... which by this point, will be
The heart willing.
Engine machine work was done many years ago and I found out the day I picked it up at the shop that there were two other jobs that needed to be done. Align hone of the crank, and also on the big-end of the rods. This was due to ARP bolts being used (but, not available at the time of machine work). While we're going back to the machine shop ("the", but not the same one), I will going for balancing, as well.
Before this can be done, must make two decisions.
One: Do I use the lightened crank pulley I purchased? Answer: Probably not.
Two: Which clutch, pressure plate and flywheel do I use? Answer: Probably neither of the two clutches I purchased years ago... and yes, on the aluminum flywheel.
Well, those two answers reflect the decisions I've made based on information contained on this site over these years. I will re-visit both next week.
Starting to go back together makes me look more closely are certain finishes and I'm getting exciting about powder coating... almost as much as welding. I definitely see myself doing both in the future. Two new, otherwise, unexpected projects which could easily keep me from "finishing" in 2017.
