gsxr141
1,158
10
rochester
today i ordered some parts from the dealer. i got new valve cover gaskets, grommets and the part that covers the plugs.
not a bad way to spend $100. lol
BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
drove it and hung out at my mechanics house and him and an owner of a 05 gti were upgrading the stock turbo with a KKK K03 and installing an AEM water/meth injection kit :D
^750hp 2JZ SC300
KicknAsphlt
Occasional Peruser
Cinched up my exhaust at the test pipe, mounted and ran the wires for the wideband and the EBC into the cabin, bolted down valve covers, filled with oil, and primed oil system....then found a leak (turned out to be my turbo's oil feed line). Made an extension pigtail for my TPS connector and wired it in, remounted ISC and PCV piping, and mounted the BOV in the flange...then discovered that it's too loose. Now have to remove it (impossible with shitty Harbor Freight snap ring pliers) and figure out how to seal it better (thicker O-ring maybe?).
Yesterday: Mounted turbo and got the hot-side IC piping finished and mounted.
te72
Classifieds Moderator
6,610
7
WHYoming
Drove my car to Cheyenne, WY and back over the course of about 28 hours this weekend. Put around 500 miles on my car, which is about 4 months worth of normal driving. Didn't miss a beat, and managed 25mpg, which is pretty awesome considering the elevation climbs...
I can see getting 30mpg out of this car. :)
Greek
513
Ohio
Fixed a leaking radiator drain plug and got some schmutz out of one of the pins of the window button. The passenger window wouldn't roll up from it's button.
gsxr141
1,158
10
rochester
yay. i replaced my valve cover gaskets, and center cover. i even used stainless bolts/washers, and new grommets.
unfortunately when i went to do the cps o-ring, i found it leaking internally.
now i'm on the lookout for another cps.........
gsxr141
1,158
10
rochester
thanks. that's the kit i need. i was just hoping to do the 0-ring without re-timing the car. oh well, i guess i'll do it right the first time.
Turbo Habanero
4,229
Tucson,AZ
My new bov setup
KicknAsphlt
Occasional Peruser
Yesterday: Finalized mounting of cutoff switch, put new oil feed line on turbo, mounted radiator and hooked up hoses (have to take back out though to mount probe for fan controller...D'OH!), primed oiling system, put front of motor back on (timing covers and crank pulley), scratched my head on alternator tensioner (Sethron just put me straight with that though), filled trans with gear oil.
Today: Vacuumed the car pretty thoroughly (mice used it as a playground for about a year), wired up EVC, put shifter boot back on, got shifter height sorted, and moved the t-handle from my old shifter to the new one.
mcammarn
matt
Feb 24, 2012
668
olympia wa
how was hooking up the evc? i have a evc6 i need to do. just looking for help.
KicknAsphlt
Occasional Peruser
Haven't done the vacuum lines yet, just did the wiring -- ran the extension harness through the firewall the other day, and finally plugged it in at both ends. Wasn't difficult, I ended up putting the EVC in the map pocket under my stereo; drilled a hole in the back of it to pass the connectors through.
