supra90turbo said:This time, be real persistent about the bearing brand they're about to use.![]()
tlo86temp said:my knocking was from the cam gears, if that helps =P
IJ. said:It was the "7M Gnome" with his little hammer!
n2fishin69 said:My 86.5 Supra has the exact same noise and symptoms! I am in the process now of pulling the engine because I suspect rod knock. Sunday, I was taking the flywheel bolts off and one of them came off with very little effort.
927mgtepat said:Jim, I hope everything works out for you. What Brand TB are you running?
