Things I don't like about Supras
Dirgle
Conjurer of Boost
Pauma Valley, CA
IJ. said:
Dirgle: And to further confuse things add the bolts rfrom 2 more dead 7M's to the bucket and shake! :D
The funny thing is, I have that bucket (as I’m sure you do too), but I keep it very separate from my current Supra when taking it apart. It comes in handy thou, when I'm missing a particular nut or bolt.
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
...and nobody's mentioned the starter?!:aigo: There was really no better layout than to hide the back bolt in a tight place? Maybe I've missed something, but I'm still scratching my head on how that's coming out so I can tackle my KS rewire. Also, Coil pack location, head bolts, and cup holders.
Back seats? If they weren't there, I wouldn't have bought the car. My 4 year old and his car seat fit fine back there every day. ;)
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
LouKy: You need to get a 3-4 ft extension and a 14mm wobbly socket to reach the starter bolt from under the car. It took me 20 mins with the right tools. :)
Also, I think Toyota did an excellent job designing this car for the most part. I just got done putting a piston in my sisters ford exploder and I swear that ford designers got together and went the other way saying "how can we make this harder to work on? so we can make more on dealer repairs"..
I love this car...Except the freaking cup holder of course...:(
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
A 3 - 4 Foot extension? I took a quick look, and I'm not sure just where to come in from, but that was looking from the top. If I can get it done in 20 minutes, I will try just about anything. Thanks :icon_bigg
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Yeah it's not easy, but there is one place on the drivers side by the rear of the transmission where you can see the backside of the bolt and get a socket on it if your good.. I also used a set of locking plyers on the front nut to keep it from spinning while i was down there..
Ok, back to the supra bashing...:)
Tanya
1,851
Naples, FL
who needs a cup holder when you should be gripping the steering wheel and holding on for dear life?
gripes about the mkII:
fuel filter is in a sucky location
starter; same as above
tiny wheels and rotors
retarded oil galley behind the upper timing cover (it seems to do nothing other than pour oil all over the engine and on the alternator)
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
the starter is not hard to get at. you just need the proper tools.. hell, if you have just a jack you can unhook the crossmember and drop the tranny a little and use a regular ratchet on it.
Tanya
1,851
Naples, FL
ehe, some of us get into crappy situations.
one time my starter actually cracked off the bellhousing as I was backing out of a parking lot causing a horrible grinding noise. it was just me and my girlfriend (read: girl friend cause I dont swing that way folks, lol) and some various tools.
used the scissor jack, popped the starter out and bummed a ride to Advance for a new starter. It was worse putting the starter back in rather than taking it out. thankfully, tiny hands got the job done.
and might I add, laying under the car in a parking lot of a convenience store in a slummy part of town while about 6 or 7 guys looked on in awe was not an experience I want to repeat.
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
BosoMKII said:
Dist bearing? I will be sure to replace that as I go over the engine replacing gaskets and other wear items.
When he said DS bearing, he meant the driveshaft center support bearing, not the distributor bearing :)
Oh and my contribution is the rear KS. WHy do I have to remove the damn starter to remove a plug? Though I have gotten to the point where I can fandangle the plug off without starter removal.
BosoMKII
497
NorCal
Ah, thanks. The bearing on the drive shaft I have laying in the driveway seems to be fine. But I don't think I will end up on the car after all.
gp-7mgte
Ramrod
May 29, 2005
221
under my hood
oil filter location, every toyota car i have ever seen has the oil filter located in way that you either have dislocate your hand to reach or burn urself on the exhaust manifold. all the FWD V-6 toyotas have the oil filters under the exhaust. IS300's have them squished agianst the fender.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
lifesnotfair said:
Many people have problems with the speedo cable, seems like a factory flaw.
A speedo cable is a wearing part. It's designed to wear and take a beating so the speedo gear doesnt have to. Its alot easier to replace a speedo cable than a speedo gear in the tranny. Theyre sposta break. :icon_bigg
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Ditto... I've got a MASSIVE collection of bolts from MKIIIs. All courtesy of the friend I bought the car from.
Personally, the only two things I can think of that really bother me are the design of the end links (Damn I hate cutting those little bastards out!) and the HG torque specs. Everything else I've had to fight I must admit are merely due to the vehicle's age.
