sadly no...
BUT i have alot more put together. i re-did the cam seals and checked the crankshaft seal and both are good. rear main is good as well. i re-did the timing and that worked out great. i have alot more put together now. i'll have to take more pics on a better digital camera cause mine is a piece of shit. i still need to install a few things still. the next main thing i'm doing is installing my walbro pump. i do have a couple questions....
i know how a car works and everything and what it takes to run...not necessarily well, but atleast run. so if all is well and all the coils are working, cps is good and all that jazz. i should be able to throw on my throttle body, connect everything electrically, install the pump and it should start. BUT when it comes to a performance motor and all the accessories i have added and still need to add on, i'm wondering if it would be bad to try and start it that way??? it would be the FIRST start up and i'm supposed to kinda run it hard to seat the rings, but i don't want to run it hard cause it wouldn't be running at its full potential. so how should i go about this? should i just keep installing things that i have? or just do what i need to do just to start it for now just to see i'm doing everything right?
i need input!
thanks!
...trying to stay awake for some Black Friday shopping
it's gonna be fun
...just thought i would add that in there
thanks, t3d
