The Small Questions Thread
BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
I want to use permanent high heat loctight on the studs for my turbo but it's only good up to 450 degrees. What else could I use? Besides jb weld. That's my last option lol
Sent From My HTC One S using Tapatalk 2
Nickel antiseize on the nuts, I'm assuming this is so the studs don't screw out with the nuts?
BoostMonger
Sep 5, 2011
880
Shadows of Utah
So the studs don't screw out of the manifold, I have studs holding the turbo on.
8,898
RPSil13;1880038 said:
question about tail lights
tail lights wont turn on at night/when headlights are on
brake lights work, bulbs appear ok
any insight or point me in the right direction, what should i be looking at
thanks
Do the tail lights turn on with just the marker lights on?
8,898
mkiiichip;1914066 said:
Quick question, am I reading this right?
AC fan #3 shuts OFF, with the headlights ON? If so, why? Simply to not overload the charging system, or another reason?
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=144
I might be missing something myself. Or they just don't show the full circuit and the missing half of the diode. Assuming they just don't give the whole picture on the headlight circuit, like the red wire coming from the relay, then the headlight switch completes the ground circuit. I am pretty sure my fan turns on whether headlights are on or not.
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=060
BoostMonger
Sep 5, 2011
880
Shadows of Utah
This is what I went with. Resbond. Good up to 2100 degrees Fahrenheit
Austin2048
209
Kaukauna, Wi
Would this make my car run like crap? That line has always had a slow leak but now the clamp broke and is spitting coolant everywhere. My car started running terrible and when i popped the hood I saw this.
Sent from my MB886 using Tapatalk 2
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
Austin2048;1945750 said:
I'm being serious. I'm a noob with 7m's so cut me some slack
The coolant leaking into the spark plug valley will short the plug wires and cause the spark plug to not fire...
Austin2048
209
Kaukauna, Wi
Makes sense. But I didn't think about that because when I first got this car the front portion of the valley was completely filled with coolant and it ran perfectly fine. So I figured a little bit of coolant down there wouldn't effect it this bad.
Austin2048
209
Kaukauna, Wi
That was the problem suprasick. I should have checked that first. It was pooled up waaayyy more than I thought it'd be. It was flooded from front to back
Austin2048
209
Kaukauna, Wi
HMNGSupraMKIII;1945825 said:
Also, get rid of the green coolant and go buy Toyota Red coolant. Expensive but worth it
Yea, I've been hearing a lot about that Toyota red vs regular green. My car had green when I bought it. I'd ask what the difference is but I can probably find everything I need to know and more if I searched.
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
Good to hear that fixed your problem. It happens to a lot of people when they try to wash their engine bay and spray down the engine.
