My thoughts
Doing something because nobody else has is just dumb. That isn't a reason. Are you going shove a hot poker up your ass and then chop your dick off because nobody else will?
Stop posting that phony 7MGE blower. Our car does not have a mass air flow sensor, it uses a vane air flow meter.
On a built race car, especially in a bracket class, a centrifugal supercharger wtih a cogged belt is probably the best idea. It will be the best due to consitency, not in total power output.
Turbocharging is a form of supercharging. So Mercedes Benz engineers are rednecks? Wow. Yes, that is what you implied. Blowers are for rednecks.there was never a supercharged supra anywhere unless some redneck got hold on one and bolted on a blower.
Then how do you plan to lubricate the blower. Some kits, which we don't have, are self contained. The good ones are not.and i didnt want to tap the block for a 1/2 NA-T,
Toyota has run factory superchargers. So has many other automotive manufacturers.I could be wrong but I am betting the engineers at toyota and all the other companies might know a bit more and had good reason to run a turbo and not its half witted lil brother the supercharger so I say lets explore the snail route a bit more.
