Somebody's New Setup
Duane, that car is going to be way too awesome to drive around in. You're going to have to park it in a garage and charge admission. There's too many idiots on the street to be driving it......................:love:
How would you insure something like that? Can you insure it for fifty thousand instead of the three thousand they would try to give you if it's totaled?
More pics please............when ever you get them of course.
hardcharger
#1 935 groupie
Oct 28, 2005
186
San Diego
DAMN, duane that engine bay is CLEAN!!!! car we plan on seeing any "special" parts coming out due to your build? mabye a hood to accomadate your turbo? just wondering. I have to say incredible attention to detail, looks amazing can't wait to see the finished product.
Dec 3, 2003
6,653
Canada
As far as "special" parts I assume only in cf? If so, no cf yet. The turbo will clear the hood no problem as Ron has a mock up car down at his place that we tested the turbo on first ;)
I do have some one off parts made and being made. (Mainly CNC).
Billet steel cams from TED as mentioned along with many new little brackets for oil cooler, crank trigger as seen in pic (look closer) to name a few. I will take pics as I go but have none of those at this time.
Thanks for the comments and I WILL drive the car like always and everywhere. I have it insured for what it is worth but will have to reappraise the car when I put it back together this year. I do know what you mean when it comes to accidents though. Mainly I am in front of the traffic, that way it is more safe ;)
Duane
Addmission starts at 5 bucks LOL Thanks again for the comments. :)
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
damn duane that looks so good
i need to wipe up the drool real quick, cant wait to see it running with this setup
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Wow, i just caught this thread.....
Lookin good Duane and Ron. Not that we expected any less than perfection....
Gimme a call Duane, we need to catch up :)
Thanks for the comments and I WILL drive the car like always and everywhere. I have it insured for what it is worth but will have to reappraise the car when I put it back together this year. I do know what you mean when it comes to accidents though. [Mainly I am in front of the traffic, that way it is more safe ;)]
Duane
Lead dog eats no dust and apparently has no accidents...............;)
Edit: I tried to quote just the part at the bottom of his post...........but I failed miserably.
87_7MGTE
SOLD :(
Bellingham, WA
Ive seen it in person. The engine bay has to be the most beautiful thing I have ever seen. Motor looks great as always too. Im so so sad though that it wont be done for SupraFest. Oh well, Im sure I will see it soon.
Looks awesome Duane. Keep up the great work! I will be following this thread closely now that I know its here!
B
Boostaddctn
Guest
upgradedsupra said:
The site I use for hosting must be down so wait a day and hope it works again.. :icon_conf What other sites you guys use?
Duane
Maybe a penguin or polar bear ate the cable that your host uses?? :3d_frown: :aigo: hahah aight peace :chicken:
Dec 3, 2003
6,653
Canada
So pics work again as some may have noticed :)
Here are a list of parts I have done since this year started. I will not have pics just yet of these parts (some are already posted) Since people are PMing me, I thought I would just post up to show everyone :) Here they are as follows.
Toyota
-Steering Column covers front/back and underneath as well.
-Wiper arms
-Window visor on the bottom
-3 vents
-Seal for back of firewall
-Seal for hatch
-New tail lights all around
-New hood latch
-OEM flywheel
-Timing cover/had it milled to make smoother,then had it powder coated black
-Headlight surround covers? The black plastic parts that surround the headlights
-Will eventually have the entire trim replaced (if all is available) throughout Supra when I paint the car.
Extreme Turbo Systems (Thanks Joe)
-Custom intercooler 31x14x4
-Custom piping from Ron R (another when completed will post pics)
Titan (Thanks Sean)
-Titan cam gears
-Turbo blanket
-RPS clutch
-HPF 6 puck disk (from HPF Obviously)
-4 V-band for my new turbo
New block
-Je's
-Cunningham rods
-Major ported head
-OS valves
-3 Angle valve job
-Custom Billet steel cams from TED
-Custom oil pump spring
-HKS 2mm gasket
-GReddy timing belt
-ARP's etc...
-ARP bolts throughout engine...some are on backorder :(
Engine bay
-Had the entire bay stripped to bare metal then etched. Had all 147 holes filled (welded) then ground down and then primed then painted. OEM colour.
-All SS allen head bolts throughout! Including the bolts on the outside of car are SS. (from Taillights etc..as I have a local shop that specializes in ONLY SS metric!)
Turbo/manifold
-T88 34D Good for 780-820 RWHP (at least that is what most 2J's put out)
-Custom one off 321SS header from Ron Ramirez. See pics :) I decided to go this route for a few reasons. I can mount the turbo where I like it and not have to worry about it cracking. :)
-Tial 46mm wasgate with A&N fittings
-Custom SS 4" down pipe (not yet finished) but stay tuned for pics later on.
Fuel
Since I had an extra A1000 pump, I decided to go with 2.
-Twin A1000 pump's (see pics when I get them fully installed)
-RC 1000cc's
-OEM fuel rail still with custom -8 feed and -6 return (same as last year with -8feed from tank as well)
-Sump as I also had last year
CNC parts
-Seven M pulley set > both water pump and alt
-Magnetic pickup for trigger wheel
-Oil cooler brackets
-Nitrous brackets for lines (Pics coming later on)
-working on other parts..
Duane
onejz
BOOOM BOOOM BANGGG
Apr 16, 2006
163
vancouver
This is what duane should of done with the barney hat and block woot woot
Who owns this engine????
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
nate, daune, ron, jake, and slow 66. are all on this thread, I figure you guys know where to send 7m heads to be ported, so where is a good place to get your 7m head ported? btw daune best looking 7m powered mk3 ever.:naughty: :love:
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
I actually am lucky enough to have a local porter/engine builder who's doing mine... This guy has built some uber high powered motors... Ask around, see if anyone local to you has built any serious motors, and ask the right questions, make sure you know this guy knows what hes doing... But maybe someone on here knows a good shop to send it off to...
Good luck Bubba...
M
mattonedime
Guest
upgradedsupra said:
Reading this thread and I saw this pic.. BAD MEMORIES!! LOL I think I see some Doug sweat on those nasty welds.. lol
Matt
