Reign_Maker said:I actually am lucky enough to have a local porter/engine builder who's doing mine... This guy has built some uber high powered motors... Ask around, see if anyone local to you has built any serious motors, and ask the right questions, make sure you know this guy knows what hes doing... But maybe someone on here knows a good shop to send it off to...
Good luck Bubba...
kwnate said:My headwork cost over $950, head shaved, stock valves seals etc and stage III PnP. He told me his Stage III is like others IV, whatever that means :dunno: I guess that means it took a lot out. He also did the most recent work on Duanes.
upgradedsupra said:My head work cost alot more than Nate's but is a major PNP and has OS valves 3 angle valve job BUT....the guy takes forever bUT does an awsome job. You will need to know up front that he is slow and he knows it to.
Here are a few pics of this past weekend.
Ok here are some misc pics. Doesn't look like alot of work done but wiring is a bitch. (for me at least LOL) Also measured the shims for the cams, so they should be in next week!
Here is a pic of the aluminum clamps I am using to hold on the wiring harness under the rad support. Normally, the ugly plastic parts stick out in the bay from underneath but instead I have SS screws to match all the bay throughout.
Pic of underside on the support. (Normally these are plastic as I stated that point up inside the bay.
A closer look at my new ARP's (Just added this weekend...More still on back order)
A pic of the turbo in the "Mock up" Supra. The gate is going to be in a cool spot but not yet finished.
Wiring and more wiring.
bowtiebuba said:where did you get your port work at?
HellsLegion said:Good going Duane! You guys do great work!
figgie said:Duane
you sticking wiht the tec2 or are you "upgrading"![]()
You got ripped off... HA! Mine only cost me $599.96 :icon_bigg But he cut the proice in half because he said "I had your head so long and kept you waiting"... What a guy! :naughty:upgradedsupra said:My head work cost alot more than Nate's but is a major PNP and has OS valves 3 angle valve job BUT....the guy takes forever bUT does an awsome job. You will need to know up front that he is slow and he knows it to.
I'm still much better looking then you.upgradedsupra said:My head work cost alot more than Nate's but is a major PNP and has OS valves 3 angle valve job.
americanjebus said:Duane this is tempting me so much to put more $$ in my car,
need to get a shot of my car next to yours so you have a sort of before and after shot to go with the build.
If ya need any help whatsover (if theres anything i can do) let me know, would love to help out.
Keep it up!
-Luis.
Reign_Maker said:You got ripped off... HA! Mine only cost me $599.96 :icon_bigg But he cut the proice in half because he said "I had your head so long and kept you waiting"... What a guy! :naughty:
