***SM Member Horsepower List***
te72
Classifieds Moderator
6,611
7
WHYoming
I'm not even on the list, and pretty sure I hold the record (on here anyway) for stock turbos...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
tsupranami;1630520 said:
Can we get on the list? Lowly #30 & 31, but still, it's a start. My car just returned from SILV 2010 with a trophy and dyno sheet showing 363rwhp @ 1.0 BAR, untuned, baseline pull on pump gas. Stock internal 7M-GTE, Boss Sr. 57 trim, 550 injectors, LexAFM, Apexi SAFC and AVC-R.
View attachment 46189 View attachment 46191 View attachment 46192
My Wife's car also posted respectable results for the smallest upgraded CT26 available (46 trim is what the Performance Techniques receipt from 2003 says?!?!) Her car rolled in at 316rwhp @ 0.95 BAR, 46 trim CT26, 550 injectors, LexAFM, Apexi SAFC and AVC-R. The area under her curve is BIG. The car is really quick on the street and at autocross!
View attachment 46190 View attachment 46193
You're added. Your wife, on the other hand, needs two things... her own account, and a number big enough to bump you off the list, as you need to be in the top 30 to get on.
te72;1631343 said:
I'm guessing I can get on the list? 320rwhp at SILV 2010. Would have had higher but couldn't get the boost controller to cooperate so it's only on the stock wastegates.
89 Supra, 1jz, stock twins @12psi, BC264 cams, ported/polished, 3" exhaust from turbos back. Stock AIRBOX for whatever that's worth, I just think it looks cool. :)
Added!
89supra7mgte;1634454 said:
515/456 16psi. stock engine gt4088r 560s led afpr walbro 3" ex 2.5" ic safc2. still runs rich. dyno sheet soon
Dyno sheet yet???
jmcboost;1638120 said:
Can the mod add me to the list? :) My dyno sheet is on page 18.
Page references kind of suck, because the number of pages depends on what each member has their posts / page set to. On the other hand, post number (in the top right) is unique in a thread, so tell me what post number it is and I'll have a look.
Devin LeBlanc;1645473 said:
Torque Monster 7M NA-T
On a Mustang dyno..
Stock GE Motor
Felpro Head gasket
ARP Head Bolts (90ft lbs)
Stock CT26
GTE ECU/Wiring Harness
Automatic Trans
SAFC Neo for tuning
Timing at 10 degree's
9PSi Boost dropping off to 7.3 (Need to fix that) hmm
319ft lbs of torque
237WHP
Crank that up! As of this moment, you need to make it over 363rwhp to make the list.
jonny87turbo;1647603 said:
I got my car finally tuned
7mgte with comp vrp64mm bolton turbo, 3in exhaust, 40 over with cp pistons, snowperformance meth injection, 2.5in intercooler piping, DM intercooler, AEM EMS, 1000 ID injectors, dual intank walbro fuel pumps and thats about it, 20 psi on pump gas with meth 500rwhp 443wtq
heres the link to my dyno sheet http://www.facebook.com/photo.php?fbid=10150336396820577&set=a.10150336396220577.577509.442439490576
Added!
mytmk3;1685011 said:
Can I get in finally got a dyno sheet
515rwhp 435 torque @ 17psi on pump gas
7mgte
Mp t70 tial v44
Toda cams Titan cam gears
comp cams valve springs
Je's and eagles
680 injectors + single walbro
3.5" catback 3"downpipe 2.5"&3" ic pipes large fmic
Ffim q45 tb
Link g4 ecu
Os triple plate clutch
Added!
toyotanos;1685151 said:
Well then get off yo lazy butt and post up a dyno sheet to prove that You da man! :D
Actually, he'd posted the sheet a while back, and I simply hadn't gotten around to updating the list yet. So it's kind of my fault. However, if you send me chocolates, I'll let you off the hook this time. ;)
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
HKS_TRD;1685245 said:
Is it worth updating Duanes number to the figure quoted in import tuner?
Not until he posts a dyno sheet. :) I didn't even put MY car on the list until I had a sheet scanned and posted. If I bend the rules for staff, everyone will either expect the same, or scream bloody murder - and to be honest, they should.
soup
fiend
Apr 4, 2005
233
Vancouver
OK. I'll play too.
405 rwhp / 391 rwtq
rebuilt 7m w/stock internals
mhg w/arp studs
lucas pte 580's
lex afm
greddey eman blue, basic harness
t4 60 trim / t3 .58A/R hot side at 14psi
BIC tube manifold + 3.5" exhaust
NPR intercooler
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Added!
soup;1685360 said:
OK. I'll play too.
405 rwhp / 391 rwtq
mhg w/arp studs
lucas pte 580's
lex afm
NPR intercooler
And added!
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Added!
soup;1685360 said:
OK. I'll play too.
405 rwhp / 391 rwtq
mhg w/arp studs
lucas pte 580's
lex afm
NPR intercooler
And added!
8,898
On a Mustang dyno..
Stock GE Motor
Felpro Head gasket
Stock CT26
Automatic Trans
SAFC Neo for tuning
319ft lbs of torque
237WHP
http://i680.photobucket.com/albums/vv170/DevinLeBlanc/IMG_0047-3.jpg[IMG]
[IMG]http://i680.photobucket.com/albums/vv170/DevinLeBlanc/IMG_0048-5.jpg[IMG][/QUOTE]
Not bad. Consider that many stock LS1's were good for 240-250 on a Mustang dyno. They were good for 280-300 on a Dynojet.
te72
6,611
7
WHYoming
Thanks for adding me Grim, makes me wonder what I could get out of the stock twins with another 4-5psi... Trying to see if I can get in on the local dyno up at the college. Not sure if they're open for public use though.
Devin LeBlanc
1,830
Las Vegas NV.
I know I can't make the list yet, But I will very shortly! Did another dyno run on 12 PSI dropping off to 10 by the end of the run I made 303WHP 352ft lbs of torque with 91 octane thats knocking, you can see the torque and HP drop off which is the ECU pulling ign timing! Different pump gas will fix that soon, along with 15 PSI :D muhahaha Stock turbo setting records and shit ;)
I feel my HP would have been quite a bit higher if the ECU wasn't pulling so much timing, It was knocking so bad sounded like marbles on the garage floor :/
te72
6,611
7
WHYoming
Not bad Devin to put down over 300 before 5k, but isn't knocking a good sign to pull out?
Devin LeBlanc
1,830
Las Vegas NV.
yes, We did one run and it wasn't knocking, put the dyno in street mode and put a lot of load on it and we heard it knocking so backed off.. Only made 2 dyno pulls. That is with no tuning as well due to it knocking, we just left it stock pig rich.
sixpatch
Chaser
Feb 13, 2010
225
Kernersville, NC
Hey all. Sweet numbers.
Slow, I know you put in the rules that you wanted Corrected dyno numbers, but then I've also noticed that some Uncorrected dyno sheets have made the list too. I never correct numbers on forced induction cars, but I know that not everyone shares my opinion there, so I'll understand if that detail disqualifies me for the list. Not that my car laid anywhere near the top numbers, I just try hard to play by the rules. 0:)
The engine:
1jzgte (complete with hydrofan)
The numbers:
297.57hp, 319.98tq
The mods: (or notable lack there of)
Stock Cams
Stock Twins
Stock Internals
Stock Exhaust
Stock FPR
AEM Widebands
SAFCII
AVCR
Driftmotion IC and Hardpipe Kit
Walbro 255
Koyo Radiator
Southbend Stage4 Clutch
17.21 psi
Supra0089
367
New Hampshire
First time tuned and on the dyno with my build:
Stock crate motor 25k miles
JT62 Turbo @ 16psi
HKS MHG & ARPS
VPC/SAFC
RC 550 Injectors
93 octane pump
3inch DDP, RT 3" performance Cat, 3" HKS Turbo Exhaust
Spearco FMIC & 2.5 IC piping
Walbro 255
Built a340e
90 degrees, 90% humidity (Heatsoaked Intercooler)
402whp/408trq
[/IMG]
leecheater
Got a bad habit
Mar 27, 2006
458
St. Cloud, MN
Move me up. I was disappointed with only 579 rwhp. When I re-dyno in a month or so, will be jumping up a few more notches. My turbo exhaust housing and 3" exhaust seem to be the limiting factor. This will be corrected real soon.
polobai
Orlampa
I guess I can throw this up there for now.
510whp, 466lb ft of tq
Built 7m, (wiseco pistons, eagle rods, etc.) Port and polished head, three angle valve job, 272 bc cams, valve springs. Gt4082 at 20psi with 550's +meth on 93 octane. Maft pro @ 11.5 afrs.
New numbers coming soon with AEM, more fuel and boost (hoping for 650whp!)
