***SM Member Horsepower List***
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
limequat;1621250 said:
Can I go up under other? It's a Chevy 4200. Just a 3" exhaust and custom tune.
Added!
rakkasan
Currahee!!
Fort Campbell, KY
Hey Grim, can I be added to the 1jz (1.5 I guess)? I hit 458whp, Jay has the dyno sheet, so hopefully he can post it....
1.5JZ, 67mm w/ .68 hot side @17psi, 680cc top feed injectors, 1zz coils, 2jz cams, Stinger ECU, Tial 44 wastegate & BOV, 3" SS exhaust w/ rerouted dump, 4" I/C, aeromotive AFPR, Apexi AVCR and a shit ton of DriftMotion parts
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
1.5JZ, 67mm w/ .68 hot side @17psi, 680cc top feed injectors, 1zz coils, Stinger ECU, Tial 44 wastegate & BOV, 3" SS exhaust w/ rerouted dump, 4" I/C, aeromotive AFPR, Apexi AVCR and a shit ton of DriftMotion parts
Tell that slacker to post up your sheet, and I'll add you to the list.
tsupranami
Drain Bamaged
Mar 11, 2006
134
Eastern WA
Can we get on the list? Lowly #30 & 31, but still, it's a start. My car just returned from SILV 2010 with a trophy and dyno sheet showing 363rwhp @ 1.0 BAR, untuned, baseline pull on pump gas. Stock internal 7M-GTE, Boss Sr. 57 trim, 550 injectors, LexAFM, Apexi SAFC and AVC-R.
My Wife's car also posted respectable results for the smallest upgraded CT26 available (46 trim is what the Performance Techniques receipt from 2003 says?!?!) Her car rolled in at 316rwhp @ 0.95 BAR, 46 trim CT26, 550 injectors, LexAFM, Apexi SAFC and AVC-R. The area under her curve is BIG. The car is really quick on the street and at autocross!
te72
Classifieds Moderator
6,611
7
WHYoming
I'm guessing I can get on the list? 320rwhp at SILV 2010. Would have had higher but couldn't get the boost controller to cooperate so it's only on the stock wastegates.
89 Supra, 1jz, stock twins @12psi, BC264 cams, ported/polished, 3" exhaust from turbos back. Stock AIRBOX for whatever that's worth, I just think it looks cool. :)
Devin LeBlanc
1,830
Las Vegas NV.
Torque Monster 7M NA-T
On a Mustang dyno..
Stock GE Motor
Felpro Head gasket
ARP Head Bolts (90ft lbs)
Stock CT26
GTE ECU/Wiring Harness
Automatic Trans
SAFC Neo for tuning
Timing at 10 degree's
9PSi Boost dropping off to 7.3 (Need to fix that) hmm
319ft lbs of torque
237WHP
Devin LeBlanc
1,830
Las Vegas NV.
I just made more early torque.. 10.4 lbs boost made 360ft lbs of torque.. Is this a record for a stock turbo? LOL I can't get my boost to stay steady.. It started at 10.4 and dropped off to 7.0 :(
te72
6,611
7
WHYoming
With the n/a cams I believe you sacrifice top end (which 7m's really aren't built for, at least in stock form) for some pretty awesome low end torque. As for a record, I couldn't tell ya. Have you pressure tested your system, checked for leaks? What down pipe are you running? Stock elbow?
mytmk3
643
christchurch
Can I get in finally got a dyno sheet
515rwhp 435 torque @ 17psi on pump gas
7mgte
Mp t70 tial v44
Toda cams Titan cam gears
comp cams valve springs
Je's and eagles
680 injectors + single walbro
3.5" catback 3"downpipe 2.5"&3" ic pipes large fmic
Ffim q45 tb
Link g4 ecu
Os triple plate clutch
