Sheedy Built Supra
IndigoMKII
2,181
Madison, Virginia
sheedy126;1958155 said:
Stock pressure plate and I believe its a heavy duty aisin clutch. Not much better than stock
Sent from my PC36100 using Tapatalk 2
Same setup I'm using. I wondered when it would start to slip, cause it hasn't slipped on my current setup yet.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Wrapped my gauge cluster bezel sp* today.
Turned out pretty good
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
My door panels were pretty bad so I added a little fiberglass reinforcement where your arm rests.
I also took the carpet out and added Swede to the panels. I've never done this before but I thought it turned out pretty good.
Just got the passenger panel done for now
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
im running -4 feed and -10 return like indigo said.
i purchase all of my fittings and lines from siliconeintakes.com, they have really low prices and good quality parts.
still saving for a clutch but the car runs great, especially in this cold weather
IndigoMKII
2,181
Madison, Virginia
still in for that dyno. I am having an inner battle with myself about my hx. I need to purchase another turbine housing for it and its around 280 all said and done. I am considering just putting that towards a hx40 that already has a t4 footprint. oh damn these decisions.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Act stage 4 clutch and extreme pressure plate came in from drift motion!
Time to throw this bad boy in, break it in, and head to the dyno!
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
suprafreak123;1971781 said:
Niceeeeeee Supraaaaaaaa!!!!!!
Thanks!
Got the transmission pulled and flywheel resurfaced ready to be put in with the new clutch and pressure plate. I also got a viper 5704v alarm system in getting installed this week.
Also got a turbo blanket that actually fits
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Picked up some exhaust parts as well all v band
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
atmperformance;1973034 said:
vband test pipe?
I'm actually doing a v band setup that connects at under the differential so I can either run my muffler, or straight pipe
I'm not running any cats or anything, straight pipe to small glass pack, then hks hi-power muffler
Similar to the picture below but being able to run my muffler as well
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Clutch and transmission are back in ready to get broke in. Oil and filter changed and ready to go.
These fumoto drain plugs really make changing oil a breeze!
