Write it up post it in Tech and I'll sticky it1jz-Rolla;1884575 said:If it were stickied......... It would need to be cut down a hell of a lot! A straightforward guide article would be much better.
Ah, whole new ball game!IJ.;1884561 said:"Domestic" i.e. Holden forum
(I don't go anywhere near the AU Supra forums)
1jz-Rolla;1884345 said:As jt2ma71 says here, the e-brake shoe has heaps of clearance - just pulled mine apart to check and there's 6mm to spare, so no need for machining there.
This is a good point, as the step goes the opposite way to what you'd expect...... who knows why its there? bloody Subaru....... I'd be wary of machining across the entire surface from the center to the outside edge of that face though, unless you also skimmed the wheel mounting face and both sides of the disc surface to ensure they all remain true - otherwise the runout could be a problem. I'm sure your machinist only took down that stepped section though to avoid this. Good info, thanks jt.
I've got some more pics and fitting points that i'll post up once they upload.
jt2ma71;1884674 said:I've only had about .25" all the way around machined and that's enough. The transition was also beveled to prevent any structural issues. I'm sure everything was done right
mytmk3;1903387 said:I fit rx7 16x8's
