I'm sure you can have those sleeves added when you order your hose.The fittings will still work.
1jz-Rolla;1882232 said:The sleeves are usually swaged with the fitting at the time of manufacture, so the cutter-style screw together fittings couldn't accommodate them. Is that what you're referring to though?
1jz-Rolla;1882321 said:ah cool. thanks for clarifying.
jt2ma71;1882344 said:I will call XRP if they can make the lines with the anti-whip ends. Here's where I got my fittings though.
http://www.livermoreperformance.com/xrp_brake.html
spiller;1884281 said:any particular paint used? i dont want it flaking off like i see in a lot of crappy lancers haha. Ill check my handbrake clearance also. If that step gets in the way, it would mean only small portion of the shoe is contacting the hat which is not ideal. I'm assuming its not an issue but ill check anyway. So 60.6mm is safe then? Id rather have the parts ready to go than pull my current rotors off the car and not be able to drive it. Actually come to think of it I have some old rotors at home so ill take one of them down with me and tell them to match it.
yhatzee89;1884285 said:So wait a min, I have to get something else machined out while on the lathe?
yeah thats a worry, lol.1jz-Rolla;1884289 said:Not sure yet mate....... nobody seems to have mentioned/checked the e-brake shoe coverage on here yet, but hey, if people are happy to fit brake lines intended for a flared seal to a banjo location on the caliper, then proper e-brake fitment is hardly going to be a worry for themhaha
