85? said:
What exactly are you talking about? Just for the turbos, manifolds, oil and water lines, and piping. I am pretty sure it depends on the turbo you use, because those are what costs the most. I like looking at things a little different than most and from what I have come up with it might be right at 4K. Can you tell me why it would cost so much more?
Ever see how much 2JZ twin kits go for? Try $8,971.60 for the "650whp" kit from HKS (from HPF.com). I know, you want to piece it all together.
Look around more, and tell me if you find any 800whp capable kits for less than $4,000. You'd be lucky to be struck by lightning twice than have a 1JZ 800whp KIT (which would be so rare I'd soil my pants if I ever saw one even for sale) to include the intercooler, that all the pieces will bolt up, to cost less than $5,000 used.
Buy a manifold yourself. Go ahead. Just FIND a twin manifold that can FLOW enough for 800whp. Not just any twin manifold, one that will actually FLOW enough for 800whp. MAYBE a Blitz or Sard twin manifold would flow that much (800whp is just 150hp away from the designed max), but the 40mm wastegate might need to be upgraded. You're not going to find any manifold that size that didn't come off a drag/race car, and is exotic because only like, three were ever made. Oh, and expect to pay anywhere from $1000-$2000 depending on it's condition (Hint: it will probably have used IHI turbos).
Now buy the turbo's. You're going to need those if you're going to mount them and start fabbing up your own downpipes, intercooler pipes, and air inlet pipes, right? You want 800whp turbo's? Then you're going to need turbos that can flow enough for at LEAST 500hp (not wheel hp), and that's pushing the ONE turbo to the max. Expect to pay $1,000 each or more for DBB units. Don't want DBB? Expect full boost around 6,000 rpms then on a 2.5L 1JZ with units that size flowing through a huge manifold through moderate sized exhaust housings.
Now fab up some pipes. Take the car to a GOOD welder. The intercooler alone that will support 800whp is going to set you back close to $1000, with pipes, and couplers. 3-4 inch piping with reduces, and splits welded in aren't really the cheapest, and neither are the clamps that go with them. Maybe if you went with a dual in/single out style intercooler (custom end tanks? More welding?)
Now pay for welding. The welder will use high grade stock/material with mandrel bends to make the downpipe x2, weld some intercooler piping, weld the dump tube, weld the BOV, weld the O2 bung(s), make the inlet pipe(s) that go to the air filter(s) you have to provide, finish the exhaust with flanges you had to pay for, with gaskets you had to buy, with V-band clamps you had to pay for, all while the car is in a shop for about a week (if they can finish it that fast). Pay for a 50mm wastegate flange to be welded on, or just go V-band wastegate. Yeah, expect to pay $1500+++ for all that custom development and parts fab done RIGHT. That's with you taking parts you already know fit for the most part and just tell them to start welding everything. Just go ahead and throw in all the oil/water lines (dual cooling?). You can't really piece together a downpipe here, or a downpipe there, intake pipe here... they'll have to come off a kit, or be custom made.
That's more than $5,000 right there, and IMO, I'm being conservative. Quality at those levels would be important to me. So would the respected fuel system, and the cams/headwork that would be required to flow that much air for 800whp.
You want to piece it all together, and there's nothing wrong with that. I was being realistic with a time limit of less than say, three years, to obtain everything needed. If you find a K26 twin manifold, it might push out 800hp with some K27's or larger, and you can score one for $4-6K depending on how lucky u get. I'm sure even BIC's kit can hit it with the right turbo setup, and it "could" be possible for under $6,000. I just don't know about piecing something like that together without spending a lot more in the end.
You asked, and that's my opinion. It's cheaper to go single.
Good luck.
