Rakkasans build, part III (project torque)
rakkasan
Currahee!!
Fort Campbell, KY
soapra;1243537 said:
Mark everything is looking good, but in that last picture you are using the NA timing belt gear. That gear doesn't have the the teeth that the crank angle sensor needs to set crank timing. You need to use the 1jz one.
Cool, thanks Jose. I'll pull the one off of the 1JZ. Also, I'm not happy with the front main seal, it's not perfectly seated. It looks like I had bent it just a hair. I'm going to replace it.
rakkasan
Currahee!!
Fort Campbell, KY
Ideas needed for harmonic balancer bolt. I can get to the bolt, but of course it just spins since the head has been removed. I don't want to jam a screwdriver in the flywheel, so I'm open to any other suggestions...
Mark, I think I have a front main seal. If you'll get me the numbers off of the one you have, I'll check and see. I have two or three brand new ones, but I can't remember which one is for which motor.
rakkasan
Currahee!!
Fort Campbell, KY
Thanks Jay, but I bought a new one today (the NAPA one that is supposed to be blow out resistant).
I'm thinking about using a chain wrench to stop the HB from turning.....
Mark, do you know which ATI dampner you bought. It saids that they have different diameters available. Thanks.
rakkasan
Currahee!!
Fort Campbell, KY
I bought PN 918562, I didn't realize that they sold different diameters. Seemed a little tight, but I wasn't really pushing it on because I wasn't ready to.
Where is the different diameters specified? Have a link for me to look at?
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
lookin good mark!
can u pm me what all uve needed to do this? hg, timing belt, etc?
ive got a chance to pick up a TT block for 150 so im considering 1.5
rakkasan
Currahee!!
Fort Campbell, KY
Bigzavs;1245188 said:
lookin good mark!
I'll just put it here for future use of other people :sarcasm:
  • 2.5mm MHG. That gives me a calculated C/R of 8.8 - 8.9
  • 1JZ gasket set
  • 2JZ-GTE oil pump
  • oil filter sandwich plate w/ oil line (length to be determined and fabbed)
  • 1.5JZ water neck (from Aphxero)
  • 2JZ timing belt
  • 2JZ accessory belt
That's the 'needed' list. I also am putting on a new hydro pump, power steering pump, starter, had the bottom end and the head rebuilt, ARP head studs, 650cc top feed injectors, solid motor mounts, AVC-R boost controller replacing my current Profec E-01, 2JZ ATI harmonic balancer. Since I use a Stinger ECU, I want to eliminate as many vacuum lines and sensor wires from the harness.
H-O-P-E-F-U-L-L-Y with the added displacement and higher compression ratio, I'll have a shit ton more torque & a much lower RPM-full boost car. I'm not looking to run a lot of boost (15-17psi) to make a lot of power (500whp-ish), so 8.9:1 C/R should make the car a lot more fun to drive.
rakkasan
Currahee!!
Fort Campbell, KY
IJ.;1245345 said:
LOL just yanking your chain Mark ;)
In hindsight I should have gone Jz from the start!
I knew you were just joking, I should have thrown a little smiley in there.
Did you just say that you should have gone JZ? :sarcasm:
meth session didn't turn out soo good Mark and Ian and anyone else reading this.
500rwhp and 46X torque @ 18.5 psi and more timing. For some reason, the fuel wouldn't change when I added it up top or took it away. I could change the fuel pressure and everything would change. It drove fine on the way home though after making fourty something pulls.
Been saying it for a few years now ;)
What do you mean "the fuel wouldn't change"?
rakkasan
Currahee!!
Fort Campbell, KY
Was your ECU not responding to input or something?
I would add 10% more fuel in higher rpms as 17psi and it wouldn't change the afr's. Even taking some fuel out would leave the afr's practically the same. I've got it tuned to an 11.5 all the way to redline though so it's all good.
We kept increasing the timing one degree at a time and it kept increasing the horsepower about nine more horses. When I got there I was at 16* making 460rwhp, and now I"m at 20* making 500 @ about the same boost pressure. My last dyno had a max boost pressure of 18.5, but it was closer to 18 everywhere else. I was told to increase timing until you kept getting better results and then to back it down. My last increase was a half a degree and it still gained four more horses. I left it right there because I was sleepy and ready to go home. This was at ten thirty last night and I had a two hour drive home.
During the middle of the runs we kept running out of fuel and we then found out that I was only getting 9.1volts to the injectors. We removed everything out of the back and wired in some larger wires directly to my battery with a relay and now I'm getting the 12 volts needed. The pumps are twice as loud now. Sorry for the long post and for hijacing your thread Mark.
williamb82
907
4
Tampa, Fl.
where is the oil sending unit on the 2jzge? if its on the exhaust side why not just tee off of that for the oil feed instead of using a sandwhich plate and long as line from the other side of the engine?
dok33
Apr 16, 2005
934
Austin, TX
It's on the intake side behind the a/c comp, either way you have to run a long line either through the timing cover where the wiring goes through or around the back of the block.
