So, now it's time to choose a new turbo. I had the bottom end built to take 700 Lb Ft of torque, but I don't want to break any of the stock driveline parts. Here is the rundown of the upgraded parts, or new stock parts. My set-up: New, 7MGTE, Yellow plug engine wire harness, new Denso 2JZtt FP (12v mod) through new wire and relay, new Denso 550cc inj, new 7MGTE FP regulator and damper, J-tube deleted as of 1-7-11.
Used, Lex/MAF w/SONIC screw, Blitz electronic, dual SBC, AFC NEO, and JDM TCCS ECU.
I don't want to break any of this: CR is 9.4:1; Fully built, forged bottom end (Eagle rods, Probe Pistons), new main caps, ARP mains and rod fasteners, torque plated, and plateau brushed over bore (20 over), new MLS gasket, port/polish, fully radiused valve seats. Extensive exhaust port work, nickel/bronze valve guides. Stock valves and cams, w/100# Comp springs. Lightened 6M crank (bull nosed and radiused and balanced with Fidanza 11 Lb flywheel and stock pressure plate and 7MGTE clutch. Stock intercooler, LIPP hard pipes. Five year old Jaws gear and axle one piece Alum DS, Jaws rebuilt R154 and 391 LSD.
I'm looking for usable power between 3500- 5800RPMs. Know of a turbo that can do the job?
Thanks.
Van
Thanks. Van
