plugs toast after less than 10 miles?!?!?!?
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
ok just checked the lines under the car nothing is crushed or kinked havent checked the ones in the engine bay yet..........anywhere else............ this is more annoying than anything think it could be a boost/vac leak somewhere else where i cant find it with my boost leak tester?!?!?
joliroger4
Flying Dutchman Pilot
Apr 4, 2005
264
New Jersey
www.geocities.com
I'm a little confused. I am seeing Champion plugs in your pictures, but your writing indicates otherwise. Put some NGK 2330s(BCPR6ES) or 3330s(BCPR7ES) in it and troubleshoot from there if you were running champions.
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
champions are what i put in there for only 1 day till my NGK's came in i have NGK in there now no change same problem. New fuel filter and still the same problem no squashed or kinked lines anywhere at all ive been having this problem for a while actually. took battery out to recharge it put it in and car ran fine no problems until the ecu re-learned i think then same problem. No CEL at all or stored codes everything runs beautiful until i start to accelerate then it starts doing the whole bogging surging and sputtering. Also im getting small backfires or missfires under decel if that helps
Unhook the fuel line put it in a bottle/bucket and jumper the Diag block and turn the Ign on and see how much flow you get.
Do this before the Rail In and again at the FPR out.
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
diag block where?? which terminals and so forth and how much flow should be there??? and are there differences between the N/A and Turbo fuel pumps???
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
FUll N/A-T swap full turbo electronics turbo injectors cleaned and flow tested to 440cc and i have a turbo fuel pressure rail with regulator and pulse dampner in place. Basically eveyrhting from the headgasket up is from a full turbo motor
joliroger4
Apr 4, 2005
264
New Jersey
www.geocities.com
Like IJ said then start checking out the fuel system. A fuel pressure gauge would be nice. It would let you know you have pressure to the rail and if the regulator is working and raising FP as it should. Even if it was temporarily rigged just for troubleshooting.
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
thanks for the link but right after i posted it i remembered my how to not be a newb thought and seatched for cygnus and found that all got a tester and all that testing it tomorrow and almost eveyr NA-T swap ive read has said nothing about fuel pump difference but then some just changed it out for peace of mind thats where im confused well either way ill know tomorrow morning what the problem is i friggin hope. And pics of the car will be up tomorrow now that my swap i finished and i got my new toys on her..............
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
ok so i did the fuel injection pressure test on my car............at idle the gauge reads 41-42psi and when i unhook the vacuum line(which has no vacuum also btw) the pressure doesnt change at all any time throughout this check procedure. Conclusion is the FPR is bad but idk if its the only problem i wont know until tomorrow night when i pick up my new one from work and get it installed and get my car running hopefully correctly. I just want this problem gone so that i can drive my car. If this regulator doesnt fix my problem then any other ideas what it might be??? My only other conclusion would be the pump............
joliroger4
Apr 4, 2005
264
New Jersey
www.geocities.com
That's too high at idle. Your regulator is bad. Either that or the vacuum line to it is bad. It is running as if there is no vacuum applied to it so it is probably not responding to boost either which is causing you to run lean under boost. It all makes way too much sense for it to not be the problem. First replace the regulator. Go from there. I'd bet money you found your problem.
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
you owe me money then bro its still doing the same thing and i even hard wired a vacuum line into the new one to see if it worked and nope so next step pump replacement then??? upgrade or stock???
Tun_x
Built to do the NASTY!!
Utah
bluedragon17;911221 said:
thanks for all the replies. ok no fuel monitoring all piping and clamps are compltely tight went over them like 3 times now correct plugs gapped at .028 and there NGK G-power platinums number bcp6egp(from toyota now in car) not running any where near rich no smoke no nothing heres a pic as soon as i can upload it they all look the same all 6 talked to seriously 5 differetn people about it they all say lean as hell.......
Dont use a platinum plug
