Ok, I guess its my turn
RTA Supra
MA70 Enthusiast
13
Tampa, FL
Wow, I've been following this car for years and I must say that it never gets old. Can't wait to see it in it's current form in person
Great job!
polobai
Orlampa
Thanks, it is ready for Tampa next week-but I have to work. Too bad nothing is going on for Sunday.....Dan-what engine management are you running?
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
I have megasquirt but its not installed and I cant get it to start on its own with my stock ECU and Fuel system. I just get it to idle and for a sec and then it dies.
zurud
351
Evansville, IN
I love your car. I really want to make my car a show car. However it is really almost impossible to drive a show car often in all weather. How often do you drive your car?
polobai
Orlampa
Dan, hit me up on the phone and I will see if I can help you get the car running-sounds like an AFM problem or other electrical gremlin if you are using the stock computer. Zurud-honestly its to the point where I only drive the car about once a week because of the gas prices, and this car has no creature comforts such as AC and powersteering. Best advice I can give you is to get a daily driver and make your show car a "weekend driver".
polobai
Orlampa
Ok-updates for the house pics that I promised(I know they are a week late) The view of the front door:
polobai
Orlampa
This is the living room setup-46 inch Samsung flat screen with an entertainment center that I made below)
polobai
Orlampa
View of back of house-the thing on the right is a water conditioning system I had installed (works wonders!)
polobai
Orlampa
My other car that the other half drives: (it usually doesnt sit that high-I guess its the way the driveway is inclined)
polobai
Orlampa
The specs are a 3/2 with about 1700 sq feet of living space and a 2 car garage-its my first house and I dont want something too big....
polobai
Orlampa
Ok, enough about my house-onto the Supra. I think I may have fixed my Q45 tps problem. I used a separate microswitch for the idle validation circuit. It seems to be running alot better now (timing is once again set to 10 degrees instead of 17!) I will make a diagram for those that may run into similar problems.
polobai
Orlampa
I also hooked up the AFR tracking on the maft pro unit-seems to be working well too, but I have the af set for 11.6, it doesnt match exactly-only gets to like 11.2 on the unit. I may have to adjust the lean limit more, or the mainscale more.
polobai
Orlampa
Yep-i live right in Champions Gate close to hwy 27 in a neighborhood called Bella Toscana. You will probably see the sup driving around there also-I was driving it yesterday.
