Here is how I connected the wiring. My car is an 88 so wire colors may be different from yours. I had it connected like X-Mans thread showed, but for some reason I could not get the idle validation to trigger, and the throttle showed backwards (100% at idle, and 0% at WOT).
Blue wire on harness goes to black on q45 harness
White with red stripe on harness goes to white (middle) on q45 harness
Brown is split into two leads-one lead goes to the red on the q45 harness
and the other goes to the one post on the microswitch. On the other post of the microswitch, goes the Yellow with blue stripe (idle validation) wire. I had to use a microswitch as I could not get the computer to read the idle validation off the q45 TPS body. You do not have to connect any wires to the TPS body of the q45, just the 3 wire harness with the gray connector is used. I know it may seem confusing, but I get no TPS code, and it works great (no rpm cut). It also reads the throttle correctly this way (0% at idle, 100% at WOT). Timing is back to normal, and best of all i didnt have to buy an adaptor or make my stock tps work on the q45-all I had to do was buy a microswitch. Please let me know if you have any questions.
