no spark no fuel on 7M-GE 4runner swap
dopeassjackson
64
ny
shaeff;1459411 said:
Hey man,
Set the cams at 12 o'clock, set the crank at 0* before top dead center on the compression stroke in cylinder 1. Put the distributor in according to the TSRM: http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=IG&P=17
Start it, let it warm up to operating temp. Jump t1 and e1 in the diagnostic block. THEN set the timing to 10* BTDC. :)
What year is the motor? 86.5-88 redline is 6500, 89-92 redline is 6250 according to the tachs.
DAMN all data told me to just the T1 and Bi terminal.
dopeassjackson
64
ny
well i figured it out. dont try to use a supra distributor in a Cressida motor. all is good now.
took the truck on a shake down run in our local wheeling compound. started to mount my winch.
back of winch is about 2in from power steering cooler.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Sweet! By the way, where is "our local wheeling compound"? :)
