Current setup (Updated Sep 8th, 2008):
Engine/Drivetrain:
-Aristo 2JZ-GTE
-USDM TTC twin-turbos
-R154 transmission
-OEM Aisin clutch (I got it cheap, and it's holding fine. )
-Jawsgear 1pc lightweight driveshaft
-Driftmotion 12x24x3 FMIC
-Custom IC piping, 2.5" from turbos to IC, 3" from IC to TB
-HKS Gen. 2 SSQV
-Custom intake w/ large K&N filter
-Custom 3" downpipe > high-flow cat > 3" catback
-USDM 2JZ-GTE water pump, FAL210 fans
-1pc lightened driveshaft
Electronics/Gauges
-Battery relocation using Odyssey PC680 dry-cell battery
-PRofec B-Spec2 EBC
-Greddy FATT
-AEM UEGO wideband o2
-Autometer Sport-Comp +30/-30 boost gauge
-Autometer Sport-Comp EGT gauge
-N/A voltmeter in place of stock boost gauge
Wheels/Tires/Suspension/Brakes/Steering:
-Gloss black '91 5-spoke wheels w/Kumho Ecsta ASX's
-Suspension Techniques springs (linear spring rate)
-Brembo OE rotors
-Axxis Ultimate ceramic/kevlar pads
-Wiisass steering rack spacers
Interior:
-Custom rear seat delete (Autopower race roll-bar coming soon)
-Grant GT racing wheel
-Lotek pillar pods
To do's:
-Replace head gasket and install ARP studs, rebuild head while it's off
-Remove ABS using parts from non-ABS donor car
Build thread:
Over the last year, I got my 1991 Supra, blew the headgasket on the 7M for the 2nd time, swapped in a 2JZ, converted to a single T04R turbo, and swapped from an auto to an R154.
Here's a little video of the buildup with the car in action.
And another with just driving and no music, slightly different footage too:
Current mods (Jan 1st, 2008):
Aristo 2JZ-GTE
R154
7M oil pressure sender conversion
T04R turbo, 4" in, 2.5" out, .81 A/R, 3" v-band exhaust, polished compressor housing
Ebay SS T4 manifold
50mm wastegate
SSQV BOV
12x24x3 FMIC, 2.5" from turbo to IC, 3" from IC to TB
4" polished intake, large 4" K&N filter
Custom 3" downpipe > high-flow cat > HKS Sport 3" catback
USDM2JZ-GTE water pump, FAL210 fans
However, after all this, my plans for the car have changed a little. Instead of throwing lots of money at big fuel system, I'd rather put it into other stuff like suspension. And while the reponse on this turbo is amazing, the way it hits is interesting when trying to gently power out of a turn.
The goal for the new setup is at least 500whp on modified USDM twins, a stock looking engine bay, and a suspension setup competitive enough to hang with the new C6 Z06 corvette on a road course. In short, once swapped to a USDM head, a CA street-legal LS7 killer.
So far I have purchased a set of USDM twins (schedualled to arrive in two days) that I will be removing all the sequencial valving from for a true twin-turbo setup without the restrictions of the sequencial setup.
I'm going to try to document this build thuroughly, so check back for updates often.
Engine/Drivetrain:
-Aristo 2JZ-GTE
-R154 transmission
-HKS Gen. 2 SSQV
Electronics/Gauges
-PRofec B-Spec2 EBC
-Greddy FATT
-Brembo OE rotors
Interior:
-Lotek pillar pods
To do's:
Build thread:
Aristo 2JZ-GTE
R154
Ebay SS T4 manifold
50mm wastegate
SSQV BOV
