suprahero;979591 said:
I bought a 2jzge block this morning so I should be able to start putting it back together after I figure out what head gasket I need. I also have my steering rack out so I can send it to Aaron for a new one. I'm also going to try and repaint my engine bay and make it all purdy.
I also have used a stock 2jzge engine as is since it was in excellent condition. The 1JZ head was not touched either.I used a stock 2jzgte head gasket for mine ( 4 layers ).
Stock 2jzge head gasket is only a single layer steel btw.I did this after reading a bit about it on NA-T forums and club lexus.There are way more qualified people on these forums that may be able to give you a more numbers/calculations kind of information and what size gasket to use precisely.
I'm just throwing this info out since I just went through this setup and its fresh in my mind
Also, I will suggest to use a oil filter sandwich adapter for the oil feed and to mount the oil pressure sender. No drilling required and no extra hoses to buy to fit the pressure sender.
