Need help with 1.5jz build
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
Jay the more i look at it the more im leaning towards a poor tune.
Justin and i were talking about it on a break at work, and the AF's were tune but something may have been wrong with the timing map
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
detonation? saw the same damage to my friends pistons but it was his 4cyl. every piston... he ran lean 24/7
My car was tuned by a trained professional and it ran perfectly with his wideband and mine so I don't think it was the tune. My timing map was messed up according to Aaron, but now it's right even though it doesn't do me any good. I'm still not sure which route I'm going to take, but I'm not giving up.......yet!!!!
George, I've got my eye on a Baltic Blue '94 with a T67 already installed.
J: Ok if you're sure it's never leaned out on power that narrows it down some.
Bent/stuck/incorrectly adjusted valve is my guess.
Can you post your fuel and ignition maps?
(hi res screenshots will do)
jugodegolf
Phoenix,AZ, United States
Don't think you'd be happy any anything other than your car, Jay. You still owe me a rematch...let me know how the lesson went.
I find it hard to believe it was the tune...car ran too well. IJ might have it right.
rakkasan
Currahee!!
Fort Campbell, KY
IJ.;975118 said:
George: This is why I asked to see the maps, all this speculation is useless without some data/evidence to go on.
Jay sent me a copy of his tune file, nothing looks out of whack, but I think the copy he had sent me was post Aaron changes....
Mark: I'd like to see the maps in use when it died.
Anything else is useless.
Motor's don't just eat parts for no reason and it would be nice for J to have a 100% answer so it doesn't happen again.
tissimo
Stock is boring :(
Melbourne, FL
+1 and valves aren't stronger then forged pistons
A aggressive tune (500whp @ 17 psi with a 35r sounds aggressive) + some weak gas from the trip = boom
p5150
ASE and FAA A&P Certified
Central Idaho
Here is a pic of the GE head: http://www.clublexus.com/gallery/data//500/medium/IMG_0045.JPG
Now here is one of the GTE head: http://www.clublexus.com/gallery/data//500/GTE_combustion_chamber.JPG
The point im getting at with these pics is that the 1j, im certain, is different as well; I just dont know the specific measurements.
I dont have any pics of the 1j CC but from what I have read on other threads it is a bit smaller. I also dont know the deck height of the motor Jay is running, but it would be pretty easy to measure the valve protrusion and compare it to the deck height of a piston at TDC to see if it was possible that the valves struck the pistons.
This should be a non-interference motor, right? Im leaning away from a mixture problem because the damage looks pretty consistent. Im putting my money on the valves just BARELY hitting the edge of the pistons when the rpms and heat started taking effect.
rakkasan
Currahee!!
Fort Campbell, KY
I wonder if Jay was running stock valve springs which could cause valve float at high rpms......
I thought it was a non interfering engine as well, but apparently not. IJ, I'll find a copy of my map before Aaron corrected it and try to post it up.
The guys at the machine shop tested the springs and said they were as good as new.........:dunno:
Try this link out for the tuning files.
www.msnusers.com/tuningfiles
I don't know if that link works for you guys or not, but click on the documents and see. I'm having problems with it, but I'm trying to solve them.
