mattjk said:Trust me, you'll get all my business... just have to find a place to re-build this turbo, the compressor wheel is chipped badly.
Got ya covered on that too!
Brewster said:2jz oil filter works
check/change the clutch while the engine's out
I agree on both : 7m filters and the stock location is very easy to change the oil filter frommattjk said:I'm using toyota 7mgte filters on mine. Why do you need a relocation kit? It's EASY to replace the filter on a 1jz.
suprastanger507mgte said:I agree on both : 7m filters and the stock location is very easy to change the oil filter from
bobiseverywhere said:is it... looking at it, it did not look easy to me. i was thinking how the hell do you get your hand up there with the steering colum and everything else around there.
mattjk said:oh, don't forget to get one of these so your oil pressure gauge works.
http://www.supramania.com/forums/showthread.php?t=27560&
suprahero said:Are any of you replacing your injectors with something bigger, or are you staying stock? I would like to make between 350-400 rwhp. I've already got a 255 fuel pump installed in my car now, so thought I might get some bigger injectors. What do you guys think about that? Good idea or not really necessary? Thanks.
do you have 550s? i have 440s and want some 550srakkasan said:I'm trying to source some JDM 2J 440's. I'm trying to get at least 350rwhp, so that would push the duty cycle way up on the stock injectors. I have a fuel pump & Emanage with timing & injector control, so the only other item I need to get is a AFPR (from Aaron since he makes a kit).
