ijs setup is waht you NEED to do with a ffim. There are several 2j threads with guys waisting motors with a single nozzle in front of the tb due to lack of flow to the #1 cylinder.
ken your killing me man, when did you get meth?!? now i have to get it...
good thing with the maft pro is you can pull the timing you add in with decreasing the airflow singnal. REALLY hodge podge now that ive seen a few cars tuned full standalone.
Feels slower is really hard to "diagnose" if you will. bigger turbo, higher boost (higher then stock) and i wouldnt dream of running anything less then 91/93. If you really feel the difference then thank your lucky stars knock control is saving your HG
. there is a limit to how much the stock tccs can pull but from my logs, you SHOULD notice if it was pulling 10*. -5* made a HUGE difference on spool up and top end when i was messing with timing control on the m-pro. Seriously HUGE from back to back pulls.
Ken stick the nozzle a few inches in front of the tb, Your AIT is upstream of that and you should be fine. Im considering straight water for an added cooling affect at the top of 4th. My Egt's hit 1600 easily with any sort of hill at 11: 1 af ratio at 16psi...
