The AEM meth kit seems like a great setup, and is well made. When this system is on and ready, you can hear a slight hum from the pump, so I think it is keeping the line primed and ready with some pressure against the check valve. When I put pressure to the boost sensor, the fluid sprays extremely fast, virtually no delay, which is great for my fast spooling turbo.
I've been boosting so much over the last couple of nights that I ran out of fluid and it was nice to have it automatically default to my wastegate spring of 10psi. I highly recommend getting a larger tank than what comes with the kit, if you do a lot of boosting. Between drag racing and some lively street driving I used 1.5 gallons of fluid per 1/2 a tank of gas.
And yes, boosting with the 50/50 mix does cause an odd sweet windex/burnt honey kind of smell :biglaugh:
I've read that some tuners like to have the meth spray come on full blast instantly at some point in the tuning map, and then it is tuned around that.
For simplicity, you could still run the progressive controller that comes with the AEM kit. I found that the biggest nozzle at full spray only made the A/F ratio richer by about 1.0, so you don't have to pull huge amounts of fuel when the 50/50 is spraying. Plus the controller does all the thinking and failsafes for you, if you want progressive spray vs boost level.
dslocal;1338300 said:I've been following this thread for a while now and am really interested in putting some meth on my 1j, I have and AEM Ems and was wondering how I should go about hooking this up? I was going to build my own tank and was wondering if I should just buy the pump, and the flow sensor? And the nozzle? Is there anything else? And what size line do you use?
