Kyle's World!
HellsLegion said:
+1ed for new technique learned.
Now would it be a bad thing if I put some DOT5 fluid in there? I know I can get it at Monument.... Or should I stick with the DOT3?
Once it's clean you can use any fluid you like!
Make sure you flush ALL of the Metho out with clean new fluid before you try to bleed the system. (might take 1/2> 1 qt to do)
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
IJ Sounds good! Ill let everyone know how it goes... I have a bottle of some DOT3 in my trunk Ill use to flush the metho out before I add the good stuff
JAV no! I just got some shaving cream from my bestest buddies (props yo) and im gonna shave my beard. My back isnt bad....
no no no no!! and NO!
Get all the same fluid!
ie: Not flush with dot3 and bleed with dot5 this is bad mmmkay!
Give the 3 to someone else and but 2 qt's of 5 to use, I used Motul 5.1 in mine and it's been great!
The 5.1 gives a bit better service life, you can get better racing fluid but it needs to be changed more often and costs more.
I haven't boiled the 5.1 no matter how hard I work the brakes so it's a good compromise, track days on slicks may be another matter though.
Big Wang Bandit
Feb 21, 2006
7,551
Ill stick with the 3 then. I never knew it was that pricey... But I guess buying it in quanity will do that eh?
Oh well. Once I go stinless lines, better pads and good rotors front and rear i might as well do my fluid the right way eh?
Big Wang Bandit
Feb 21, 2006
7,551
Looks like forever. Its almost black. I cant believe i neglected the brake fluid as I did lol. The brakes could of gone out mid corner... Not when I was stopping at a stop sign...
Lesson kiddies. Dont let the little things pass under the radar!
