Nate: Nice box!
Would maybe be a little better further forward to get the weight over the axle centreline.
there would've been targa clearance issues, the floor is a little higher just an inch further forwardIJ. said:Nate: Nice box!
Thats a good idea the box is 3-4 inches to tall.. I'll look at that this week, I'm worn out now.jimi87-t said:You can still get corrosion with out water and salt. BTW I just saw your dash mod and box, looks good! How much room do you have in the box, mine has enough extra room for about half a bat. If you have plenty of room, you could put your relay in the box?
jt2ma71 said:Nate, the only electrical connections I have out there are the 2 wires going to the pump. Everything else is inside the trunk under that wood panel. Nice progress :bigthumb:
I used the autometer cobalt full sweep gauge. It's programable so It'll be awhile before I can test it.sarichmond said:Looks Good!
What Fuel Guage did you use and Can I get a blow up?
Just got back inside.supra90turbo said:Nate: I would put all the electricals inside the hatch. It will make tracing a short/problem that much easier.
sarichmond: never use "fuel" and "blow up" in the same sentence around someone who's building a fuel system.![]()
I just need to put the hose on it and out a hole, just haven't done it yet, not too sure its needed with a sealed optima battery though?IJ. said:Nate: Can't tell from the pics but is the box vented to outside the car?
The kit came with the a vent hole and fitting on the side of the box and a tube. There was an existing hole in the floor i just shoved it through, not needed but better safe than sorry i guess...jimi87-t said:Looks good Nate, I don't have mine vented, it's an optima also. I guess the easy way to vent it would be to drill through the bottom of the box and the floor of the hatch.
