JT2MA71's Build. Dyno video on post # 1191
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
read but just found otu about the vavle witch is for dry sump or vac pump
but what is the other one that si the one i was trying to figure out
NashMan said:
what is that on your vavle covers ajustble vent of some sort link me that looks baller kidna wana knwo more about it
j3pz
still learning
hope this is what you are askin about.
jt2ma71 said:
The valves on the valve cover; vacuum regulator, too much vacuum in the crankcase created by the oil pump will cause oil starvation. Other one is a pressure relief valve, under boost, there may be positive pressure in the crankcase, this is to prevent blowing seals out. Both valves are one way.
americanjebus
Mr. Evergreen
wa.
Looks amazing but for some reason it cuts out at 2:54 and theres no audio.
I bet your one happy man right now. Good work.
jt2ma71
Impeller Head
Washington State
IJ. said:
Ron: Sounds snappy!
Congrats on getting it running :)
What is the dash layout starting Left top to right please?
(just trying to figure out what I'm seeing)
speed, fuel pressure, gear position, oil pressure, manifold pressure(wrong sensor calibration), egt, and a/f ratio.
