Poodles said:it's easy to use a torque wrench (it's longer so I have more leverage anyway)
flubyux2 said:yeah... or you can just Man-Up and do what i did...
the 7M is pretty easy to work on, as im sure you can see above![]()
Tell that to the turbos. :biglaugh:bigaaron said:I think the 1jz and 7m are about the same difficulty to work on, you just find yourself needing to work on the 1jz a lot less. :biglaugh:
they cant be any harder then a mkiii w/ a 1j.. took me and a few buddies ~ 2 hrs.. and of course the BSing that goes along with working on a car with your buddies.. lolflubyux2 said:lol.. the turbos. HOLY Shizzle. try taking the stock twins off a MKIV without CUTTING OR BENDING anything... then come talk to me. sweet jesus, those are days i wish i could unlive.
tissimo said:they cant be any harder then a mkiii w/ a 1j.. took me and a few buddies ~ 2 hrs.. and of course the BSing that goes along with working on a car with your buddies.. lol
Took me like an hour and a half to change an igniter on one once. You have to remove the entire intake system just to get at it :nono:starscream5000 said::werd:
Changing spark plugs, wires, rotor, and cap on my 6G72 took 3 hours the first time, and about 1 1/2 hours the second time after getting a bad batch of wires the first time around :cry:
It's just you.
On a 7M <5 minutes. :biglaugh:annoyingrob said:Took me like an hour and a half to change an igniter on one once. You have to remove the entire intake system just to get at it :nono:
