I put a 60mm water temp in my dash cluster the other day. Only alittle dremeling needed and it fits perfectly without any gaps. I'd definitely choose 60mm if putting them in the dash, especially the premiums because of their shallow mounting depth.Reign_Maker said:Odici, are they 60mm?
The Dude said:One question, I can't try my gauge out yet but I just noticed it came with the needle at exactly 140 degrees. Is it supposed to be at zero?
The Dude said:I put a 60mm water temp in my dash cluster the other day. Only alittle dremeling needed and it fits perfectly without any gaps. I'd definitely choose 60mm if putting them in the dash, especially the premiums because of their shallow mounting depth
Right, then just use a pencil or whatever to press them. No big deal. Might try and rig something up like the stock trip reset button.starscream5000 said:Dremel a hole in it where the button needs to be pushed.
Prosport Gauges said:
Doward said:Nice! Do you have them in the green/white yet?
Any idea of time until a speedometer is available?![]()
Prosport Gauges said:no only amber. No updates on the speedo yet..at least a few more months
