I might sell my soul for Prosport Peak and Hold gauges
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Prosport Gauges said:
reign- lol don't forget it was not that long ago that the only A/F available was a narrow band and that is what you had to use...
Thats true, but having used both, I wouldnt use a narrow band... Not for tuning purposes, maybe for disco purposes, lol... The problem with the narrow band is it has no "real time" feed back that the wide band gives you... Im not telling people NOT to buy your narrow band, but if given the choice between all the gauges available, the narrow band would be further down the list... There are other, much more important gauges to focus on than the narrow band... Besides, maybe if we keep leanin on you guys, you'll get us that wideband sooner, lol... :D:D:D
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
It sure is. I've got all 5 of my gauges wired and finally working properly with the help of Glenn (Prosports Technical Representative). Prosport has been more than helpful on several occasions. Def. get a thumbs up.
Mo
Mo87NA
8
Upstate NY
Well it can possibly be two different things. One, could be that you have not set the peak/warning setting yet. The other possibility, if the needle is pegged completely to one side, means an open electrical circuit in the system....
Mo
Mo87NA
8
Upstate NY
Yep, those are your problems!! Once you connect the sender and set the peak function, viola! Goodluck!
Mo
Prosport Gauges
Prosport, Inc.
Jul 20, 2007
70
Tampa, Fl
www.prosportgauges.com
Mo- Thanks for helping Suprra Girl-I could not have said it better..
Wideband AFR- we are getting very close. I should have pre-production samples in my hand next month!!!:biglaugh: :biglaugh: :biglaugh:
At that same time we will have pricing info and a firm release date. If you have not done so already email us direct and have your name added to the Wideband AFR list: This will get you first crack to buy them before they go on sale on the website. The new gauge will NOT require a controller. Everything is built into the gauge-with a digital readout in the center and bar graph lighting around the outside. We will offer it with or without the bosch O2 sensor.
Mark my words -this gauge will sell out!
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Will it have an additional output to output the reading to the gauge, and something like a Maft-Pro?
I doubt it would have a feature like that, for a Budget Wbo2, but if it did that would be amazing!!
dbsupra90
toonar
indiucky
I never heard of maft-pro, but it will have data log capabilities.
maft-pro is a piggyback engine management system. it has the ability to display real time a/f and also datalog a/f along with other parameters. the gauge will need to have an analog output to connect to the m-pro, and also have a scaled output similar to others on the market (innovate, aem, plx, etc) for the unit to read it correctly.
fstlane88
Single time!!
South FL
This is directed at the Prosport rep that's been posting, and it might be a stupid question. Just wanting to confirm before I order a water temp gauge. I already have the upper radiator hose adapter for use w/ a water temp gauge that you guys sell. Need to just make sure your regular WT gauge will work with that...My gut says yes but I need to be sure.
And if not can you tell me what size I will need to drill and tap it to?
fstlane88
Single time!!
South FL
Thanks!! I just placed an order for a green/white water temp gauge. Going to see how I like it, I might just replace my other two Autometer's w/ your gauges.
