Holset HX35
kneedragger85
363
Boulder, CO
kamikazemkiii;1510680 said:
Is their anyone who uses the stock manifold with the t3 adapter?
ive seen it before but like to again.
This is my buddy's setup before he got rid of his supra last summer. The turbo is a WH1C, which is the generation prior to the HX series with an undivided t3 footprint. Similar boost characteristics to my pre-1998.5 HX-35 coming on early 3k rpm with the help of the FFIM and also had a big FMIC. Unfortunately, no dyno numbers before he got rid of it.
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
This is my new engine with the HX35W. Stock Manifold. External wastegate. And a custom ct26-T3 adapter. I made it to where the turbo sits at an angle and a little above the valve covers.
kamikazemkiii
1,219
North Carolina
This is the one i was looking for. Im in for more info and pics! nice setup, are you currently running it?
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
No Its still sitting in the garage. I actually gave the whole setup and motor to my best friend for his birthday. But I still have access to it.
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
johnd;1513092 said:
I blew the seals out of my first hx35 immediatly after startup with no restrictor, IDK. I silver soldered a fitting on the feed and drilled a 1/16 hole wich flows 1.5 ltr/min @ idle. I can't remember but I think holset calls for 2 ltr per min. so when i'm driving the oil pressure rises so im in the ball park.
It's been working great for 2 summers now, turbo bearings feel as good as they did when i first installed it.
BTW this was on a 1jz, 7m oil flow/pressure is different.
what rpm does it spool on a 1jz? im looking to put a hx40 on mine, with an 18 cm housing. hopefully it wont be tooo laggy
johnd
278
Ont. CA.
Depends what gear im in, mine starts spooling just after 3200rpm and hits 17psi hard just before 4000rpm.
This 12cm exhousing on a 1jz is to laggy for me, nevermind 18cm. I just bought a bep 9cm 70ar housing for faster spool and longer powerband.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
The 12cm housing on an 6-7 blade HX40 on a 7MGTE = PURE SEX :).Thats gonna be my future, future project. For now the HY35 and 700cc injectors will do.
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
Okay I got the pics today. I haven't welded the wastegate flange on yet but its coming. And notice in one of the pics with my hand in it. Tell me whats missing.
