ifyouaint1sturlast;1817504 said:I feel that your spraying starting fluid into the intake and it still dies is proof enough that it's not a fuel issue. (If you continue spraying and it still dies - that is)
Do a test for me, and see if the car will stay on if you prop the throttle open a little bit.. can't believe we didn't think of this sooner. I don't know why we are so focused on the fuel pump? Ugh.
Do some reading:
http://jzxproject.com/bbs/index.php?showtopic=2175
http://www.toymods.org.au/forums/te...lls-dies-post-conversion-teething-issues.html
http://www.supramania.com/forums/showthread.php?148181-1jz-swap-starts-then-stalls
vIetDrIfTeR;1818285 said:well the feed line from the tank to the engine, its fine i checked. alot of gas comes out when i jump +B and FP.
but there not much coming out the return line can anybody verify this please???????How much is suppose to come out ??
i check that bro but it runs when i spray starting fluid so i dont think its wired wrong or anything525gte;1818281 said:Are your injector powers plossible not wired correctly ? Like maybe they are loosing power after the car starts maybe test power
IBoughtASupra;1818288 said:It should be the same amount if the car is not running. If its less, I'd suspect a weak pump.
I did. i extended it and matched to the ma70. i double check everything. everything seems right just dont want to stay runningIBoughtASupra;1818310 said:Who did the wiring for you?
525gte;1818426 said:spraying starting fluid has nothing to do with fuel delivery.. it goes thru the intake. not the fuel injectors. you might want to ck it
IBoughtASupra;1818345 said:To elaborate on what another member said,
Start the car, let it stall. Check to see if you still have 12V at the injector pin. Don't cycle the key once it stalls, leave it in the run position and check the pins for the 12V.
yeah sorry should of been more clearer. but the engine stays running as long i keep spraying the starting fuel fluid.ifyouaint1sturlast;1818446 said:Oh it does stay on when you spray starting fluid? I thought you said it didn't. Yes as Alan said, once it stalls, check EVERYTHING. Probe for power at the injectors, fuel pump, coil packs, etc.
Also, you can go to harbor freight and pick up a mechanical fuel pressure gauge for like $15-$20. This will tell you if the fuel pump is dropping off or if it's something else.
Uhh.. what?
