ifyouaint1sturlast;1816882 said:You want to connect your fuel pump power wire to the big black/orange wire coming from plug B1.
Most people just do the "12v mod" which is essentially powering on a relay using the stock fuel pump wiring, and the relay will feed direct battery current to your fuel pump.
Good luck!
are you talking about taking out the FP yellow wire from the ecu and connected to the black/orange wire?
