Well Sean (funkey_monkey) and stayed up tell 3:30 AM and was able to finally able to started it up!!!!!!!!!!!!! Wow this thing has some oil pressure. This 7m sounds mean!!!!! The gauge oil pressure wasent working so we pulled a cam cover to check every thing out and yep lots of fresh oil coming out. But just to make sure we pulled a oil cooler line on start up to double check, and it shot oil out of the hose like water coming out of a garden hose.!.!.!.
A couple questions, First dose anyone have 272 cams and a ffim? I ask because I have 0, thats right no vacuum pressure. Gauge is working, When we pull the line off of the intake manifold there in super little vac. Like 2-5 inHg.
Also we were able to build 5-6 lbs. of boost wile sitting in the garage just reving the engine!!!!!!! I have never seen any turbo car build boost while not driving!!!!!!!!!
Fuel pressure gauge is reading around 55 psi with this no vac. going on.
Dose this have to do with the 272 cams????? FFIM?????? Is the custom made 4" TB I got from tubbie some how fubared up????????
Also My gauge cluster is dead, the lights turn on but nothing else works, No tach, oil, boost, water temp. I just pulled the glove box and all body plugs anr together and tight. Also pulled gauge cluster and all harnesses are pluged in there also. What gives?
Any ideas what to try next. Also there is a massive oil leak on the from of the engine, looks like the from main seal behind the lower timing cover.
looks like my engine builder is going to get a phone call :cry::cry::aigo::aigo:. Well over 5 g's for this rebuild, it better not drip a single drop of oil untell there is 70k miles on the engine.
Vid. of cams to double check oil
video of first start up.
And another trying to get it to idle.
