Damn. Random objects in the engine, the wrong nuts on the head studs...why are machine shops such pieces of shit? Did you move the piston down and inspect the cylinder wall?
IJ.;1894118 said:Look at the Compressor wheel and cover, has this IC been used before?
(My "guess" at this point is no oil pressure at the start and a tight compressor wheel has shaved some of the compressor cover then blown it through the IC into the engine.. )
IJ.;1894122 said:Magnetic rules out the wheel/cover, hmmm
Suprapowaz!(2);1894170 said:MySupra, what's the story behind the gift? You have a link to it?
MySupra;1894181 said:Fo shoo, homie.
http://www.youtube.com/watch?v=iQ1-jSvxMJ0
Quin;1894152 said:I'm thinking this was good luck. Block is still good head is probably repairable.
MySupra;1894159 said:Damn, read the whole thread while at work. I need an energy drink.
ShmoupleDupe;1894186 said:So, I've read this entire thing, and I must say, I had some pretty real feels for you starting up every once in a while.
Some bad luck has come with the building of this car, and some pretty low moves by a few people.
Even though you found the shavings, I think you should recheck those spark plugs
Just kidding, but this is looking like a fantastic project, and I hope you the best of luck with the continuation of it! It's starting to look pretty amazing
stevenr816;1894131 said:Like I said the piece is magnetic, and was flat originally, then both sides folded making it a roll.
