I could use some thoughts from everyone. My car runs great as long as it doesn't make boost. As soon as I get to 5 in vac or to 0 my car starts cutting in and out. I just installed a a/f gauge and when it cuts out my a/f Jumps up to 16 or so. I thought it might be the fuel pump so I swapped it with a known working one from a mk3 and that didn't fix it. The fuel filter is new as well.
Is it possible for the mas is going bad? I did try unplugging the coolant temp sensor and then the o2 sensor to make it run richer and it helped. Like that I can boost 1-2 psi before it cuts. Any thoughts????
