Fuel cut? Misfire?
Oct 11, 2005
3,819
25
Thousand Oaks, CA
Its a shame it took 57 posts to find out you have a code 34, cause that would have saved everyone a lot of guessing. I suspect your next post will be that the problem is solved after fixing the leaks.
Most run of the mill meters cannot accurately measure small resistances like 0.5 ohms, so when you measure 1 ohm consider that it is close enough to being correct.
RTtim
90
lake isabella
I have checked every couple days for codes and have always came up with nothing. Now I am not going to promise that I wasn't doing something wrong. Maybe the jumper wire never made good enough contact or maybe I even jumped the wrong pins. Anyway, I will see soon if the leaks it did have actually took care of the problem.
RTtim
90
lake isabella
To those of you that feel I might have wasted your time with questions and ideas I am sorry. I would have normally agreed with the possibility of a boost leak if it didn't seem to be affected by temp. So any way, I found a two spots that leaked at a low psi and two spots that leaked at a higher psi. So the problem is fixed and I have my car back. Thank you everyone for your help and patience with me.
Oct 11, 2005
3,819
25
Thousand Oaks, CA
I'll retract my statement. It sounds like you made a good faith effort to grab the codes and just didn't get any, which is weird. The good news is that it was a boost leak and you solved the problem.
RTtim
90
lake isabella
I am gonna burn my car to the ground. I found a boost leak at the injectors( two of them). Pulled out all the injectors and replaced the all the o rings. Primed the pump to check for leaks and no fuel leaks. Put my car back together and now the damn thing won't start. It cranks just fine but won't start. I dont get it.
RTtim
90
lake isabella
If the cps is based on magnetic pick ups, how it is they can just go bad over night? I mean I replaced the injector o rings yesterday and then did actually take the car for a spin an everything was fine. Went to get in my car this morning to go to work and nothing, wouldn't start.
