eraezer - Supra MK3 -89 -Swedish Build
CBatstone
Burlington, VT &Wolfeboro
Sep 22, 2006
84
Vermont
www.thirtythree.org
I've really enjoyed following your progress, your work is quite thorough and very impressive. You took on this restoration and rebuild with an approach of enhancing stock components in a way seldom seen in automotive restorations. There is just one thing I can't understand, you said you are sad that the car is now running and not torn apart in your garage? I'm always quite happy when my supra gets out of my shop, which ends up happening a few times per year. So if it is any condolence to you, rest assured as it will probably be back there soon = )
eraezer
851
9
Stockholm, Sweden
Thank you very much for those kind words :)
You misunderstood me, I'm sad that I don't have any garage for the supra now, so he stands outside in the snow.
This project is far from over, I still have some stuff to do before I have completed "stage 1" and then I can do as many stages as I like :D but with driving time in between of course ;)
I might be lucky and will get another spot in the garage where I keep the porsche, and I will even get it next week.....if I'm lucky :) so keep your fingers crossed, thats what I'm doing :)
eraezer
851
9
Stockholm, Sweden
-:|Update - 2010-12-16|:-
Today I visited my lovely supra :)
There were a lot of snow on him.
Decided to start the engine and move the car so that I could remove all the snow surrounding it.
To my surprise the left headlight motor started to get signals, so it opened and closed like it should :)
The left position light did not work which it did the last time I drove it :-/ Hopefully it's just the lamp that needs to be replaced.
I also looked at the front left ABS sensor connection and inside it looked new, so no easy fix for error code 32 and 34.
I checked the resistance, but there was nothing to measure :S so I think I have a broken wire.
This weekend I was about to drive 300 km one way to pick up an engine, but the seller sold it to someone else without telling me first :(
So no new engine for me to prepare :( I had even arrange with my boss to work overtime and for that he would lend me a truck so that I could pick up the engine.
LOL'd @ this :D
Couple of weeks back I drove 670 Km's one way to pick up a tray for the Ute, then turned around and returned the same day!
(guess living in Australia I'm more used to long distances as going out for Indian food Tuesday night was a 250km round trip)
eraezer
851
9
Stockholm, Sweden
-:|Update - 2010-12-18|:-
LET'S DO THE HAPPY DANCE!!!!!!!!!!!!!
Today my supra got a new home :D
It's in the same garage where I got a spot for the porsche.
So now I have one workshop spot and one storage spot there.
So whichever car needs work will be in the work spot.
For now the supra will have that spot so that it will be ready for the summer ;)
eraezer
851
9
Stockholm, Sweden
-:|Update - 2010-12-20|:-
Today is the big day! It's time to move the supra to the new home :D
I was very nervous since it was very slippery outside in the snow.
I had a friend following me just in case something would happend.
When we go to the garage I emptied the trunk from the last boxes of
stuff that I had brought from the old garage and then we took my
supra out for a spin in the snow ;)
It was so much fun!
Now I need to get the supra ready for inspection.
Pictures:
Ready to move to the new garage
Resting after an evening of fun in the snow
The porsche had to move to the other spot
eraezer
851
9
Stockholm, Sweden
-:|Update - 2010-12-21|:-
My first workday with the supra in the new garage :)
The idle was a bit off sometimes so I decided to clean
the IAC valve.
When I re-installed it I used new gaskets which came
with the gasket kit I bought from driftmotion.
Pictures:
IAC valve taken apart
Assembled and installed. A little cleaner, a little better
eraezer
851
9
Stockholm, Sweden
-:|Update - 2011-01-07|:-
One thing I had to take care of to even have a chance to pass
inspection was the windscreen squirters.
One was broken.
In a swedish store called Biltema they have two diffrent set
of universal windscreen squirters, I bought one set of each.
One of the worked without any modification which I already
knew thanks to the swedish supra forum supras.nu.
But I forgot which one and thats why I bought both the sets.
I only installed one squirter in place of the broken one,
will change the other later.
The new one works better than the old stock one.
Pictures:
Old windscreen squirter
New squirter
I still have to clean the carpet
eraezer
851
9
Stockholm, Sweden
-:|Update - 2011-01-09|:-
Today it was time to do something about the paint since it
has been neglected for about 2 years.
I used rubbing, polish and wax on the hood and roof.
That was enough to make me feel happy when I drove of to
work a graveyard shift :)
Pictures:
I did som rubbing, polishing and waxing, can you spot where?
Heres only a part of the targa roof done, you must see it now :)
Complete roof done
eraezer
851
9
Stockholm, Sweden
-:|Update - 2011-01-12|:-
Today I decided to clean the air filter since I forgot to put it in a bag
for protection from dust and so on.
I sprayed it down with degreaser first and let it sit for a while.
Then I washed it of with water.
It went from red to white/gray :S I think I need some new filter oil.
Pictures:
Air filter before with degreaser
And after
eraezer
851
9
Stockholm, Sweden
-:|Update - 2011-01-13|:-
I got some hardner for the polyester today so I fiberglassed the antenna hole
in the side piece for the wing.
The hardner was like the ones you use for putty. I have only used liquid hardner
before so this was a little bit of a test.
Pictures:
Taking care of the antenna hole
eraezer
851
9
Stockholm, Sweden
-:|Update - 2011-01-15|:-
I think I need to use a little more hardner next time.
Most of it is dry but some parts of it needs to dry just a little more.
I sanded down the top side which is now ready for putty.
Pictures:
The fiberglass is almost completly dry
Top side ready for putty
eraezer
851
9
Stockholm, Sweden
-:|Update - 2011-01-17|:-
As you can see in my pictures, my carpets are very dirty.
So I tried to cleaning them a little. But I need to get some stronger cleaning stuff.
I also started on getting the door trim smooth.
Pictures:
Driver seat removed to be able to clean the carpet
The trunk carpet also needs to be cleaned
Door trim ready for putty
Carpet is a little bit cleaner, but not enough
Door trim installed
Trunk carpet also needs more cleaning
First round with putty on the door trim
eraezer
851
9
Stockholm, Sweden
-:|Update - 2011-01-21|:-
Today I started with removing the front to get a look of how the IC is mounted.
I also removed the diff and the rear half of the exhaust.
As you can see, I have a big leak from the diff so I need to change some seals.
I cleaned the diff, both on the inside and the outside. That diff oil is tough.
Pictures:
Front Bumper removed and getting ready to remove IC and pipes
The supra is a little bit wider than the Porsche :)
Just showing what the supra looks like now
Stock oil cooler which will become my power steering fluid cooler
Removed the rear half of the exhaust
Took down the diff
Leaking diff
A smaller diff leak
Diff drain plug
Inside of the diff, nothing seems broken
And the inside of the cover
Cleaned the inside of the diff
And the outside
