-:|Update - 2011-03-04|:-
Today I removed the remaining front part of the exhaust and with that came the turbo.
It was a bit too white inside the exhaust manifold and the reason is showing in the last picture,
the intake hose is broken where it connects to the turbo, so unmetered air has entered the
engine resulting in lean condition, but no knock.
I took the turbo apart to be able to use the turbine housing while I'm building my new exhaust.
I started the new exhaust with welding a plate to the DP flange which sepperates the regular
exhaust gases from the wastegate gases.
Pictures:
The front part of the exhaust is out
And so is the turbo
And now the turbo is in pieces
Testing the DP flange
Fitting a block-of plate
This explains some things
